0 Members and 1 Guest are viewing this topic. Read 7190 times.
Although it is DSLR video based - these 3 videos give a pretty good explanation on lenses, apertures, etc. - and the "meaning" implied for each use and why you would choose one over the other.http://blog.vincentlaforet.com/2011/08/15/oh-dear-the-viking-has-landed-and-uh-the-astronaut/Jim C
Ok so than a question on the following -Canon Powershot G12 says it has 5x optical zoom covers 28-140mm.The Sony NeX5n can be bought with a 18-55 mm lens -So then referencing the video I watched from a few links above from bunnyma357 how would one decide which of the two listed above is better and why? I am using this as an example to get a better understanding of the different cameras out there. The canon has a range of 56mm-140mm where the Sony doesn't in the above scenario but what else am I missing between these cameras.
Ok good place to start.Are there other cameras I should look at as well - I am not saying a dslr won't work but the more portable the better.Also probably same price range as the Sony roughly -
If one waits, there's always something better coming along these days. They come up with updated models like there's no tomorrow. Just close one's eyes, bit the bullet and buy, but only after some homework.
With Sony you can change out lenses whereas you are "stuck" with the zoom on G12. You can never go prime...
I just came back from 2 successive trips with the Canon 5DII. My shoulder/back is still sore (try hiking with it!).
