BP-27 Wish List
0 Members and 1 Guest are viewing this topic. Read 8885 times.
SoundGame
BP-27 Wish List
« on: 26 Sep 2011, 11:16 pm »
With some of the discussion on the perfect preamp, I was thinking that it might be fun / interesting to put together a list of potential areas for improvement and/or functionality.
To start my thoughts were as follows:
Given that Bryston uses discrete circutry and power transformers in it's amplifiers for left vs. right channels - would it not seem like a potential enhancement to take a similar approach for the preamplifiers i.e. a separate and discrete power supply for the left vs. right channel in the preamplifier???
Diamond Dog
Re: BP-27 Wish List
« Reply #1 on: 26 Sep 2011, 11:25 pm »
And TUBES! Lots and Lots of Tubes! Great big HUGE ones all aglow!  :lol:
D.D.
SoundGame
Re: BP-27 Wish List
« Reply #2 on: 26 Sep 2011, 11:46 pm »
D.D.
Those tend to be like a barb on the wire.... :icon_twisted:
Diamond Dog
Re: BP-27 Wish List
« Reply #3 on: 26 Sep 2011, 11:49 pm »
Remember, some prefer a few barbs... :wink:
D.D.
SoundGame
Re: BP-27 Wish List
« Reply #4 on: 26 Sep 2011, 11:59 pm »
Remember, some prefer a few barbs... ;)
D.D.
Agreed.  Even I might be caught liking them...when Pam Anderson is wearing them (insert pic)
1oldguy
Re: BP-27 Wish List
« Reply #5 on: 27 Sep 2011, 12:35 am »
redbook
  • the music is the blood...........
Re: BP-27 Wish List
« Reply #6 on: 27 Sep 2011, 02:59 am »
 Yes, Soundgame's suggestion would be great to see happen James; if there is a new preamp on the horizon. :thumb:
BrysTony
Re: BP-27 Wish List
« Reply #7 on: 27 Sep 2011, 03:45 am »
1.  Home Theater pass-through
2.  Remote controlled source selection
3.  Balanced and single ended connectors for each input and output
4.  Drop the separate power supply
5.  Line level output for the BHA-1
6.  Target price < $5000
HsvHeelFan
Re: BP-27 Wish List
« Reply #8 on: 27 Sep 2011, 02:34 pm »
Well, since no one has requested it yet:
Tone Controls!
 :wink:
HsvHeelFan
Diamond Dog
Re: BP-27 Wish List
« Reply #9 on: 27 Sep 2011, 03:07 pm »
Tone Controls!
I'm more likely to get a Bryston tube pre than you are to get tone controls :lol:
D.D.
rollo
  • Rollo Audio Consulting -
Re: BP-27 Wish List
« Reply #10 on: 27 Sep 2011, 03:21 pm »
  A dedicated outboard all out power supply for starters. A reverse polarity switch, a display light on/off switch, HT bypass, balance control or dual mono with two attenuators.
  A wood faceplate as an option.  :thumb:
charles
SMA
HsvHeelFan
Re: BP-27 Wish List
« Reply #11 on: 27 Sep 2011, 05:00 pm »
Agreed Diamond Dog.
When I get around to building my music server, I'll most likely be playing around with digital eq's.
The only thing I ever tweak on my Parasound pre-amp is the bass and then it only gets boosted or cut by 1 or 2 clicks.
HsvHeelFan
SoundGame
Re: BP-27 Wish List
« Reply #12 on: 27 Sep 2011, 05:22 pm »
charles
SMA
Ummm - the bp26 already has a number of these i.e. outboard power supply, phase/polarity switch, on/off display light, balance control, dual mono design - with the exception of the power transformer - not sure what you were trying to say here...? :scratch:
SoundGame
Re: BP-27 Wish List
« Reply #13 on: 27 Sep 2011, 05:38 pm »
To add to my earlier - I'd like to see position marking around the attenuator/volume pot, perhaps in dB with also a lighted position indicator on the pot.  This would help to identify and perhaps record the volume position (favorite) for a said recording or album for future reference.  It also helps in A/B testing to adjust for volume differences as you can make the adjustment to the volume pot back and forth to a more precise degree.
Diamond Dog
Re: BP-27 Wish List
« Reply #14 on: 27 Sep 2011, 07:26 pm »
And of course, some tubes wouldn't hurt....  :green:
D.D.
SoundGame
Re: BP-27 Wish List
« Reply #15 on: 27 Sep 2011, 07:30 pm »
D.D.
Yes - and a partridge in a pear tree... :guitar:
spinner
Re: BP-27 Wish List
« Reply #16 on: 27 Sep 2011, 07:31 pm »
 I think the power supply idea is that there could be(like the power amps) two  transformers L+R. I guess what this would mean is that the whole preamp  would be a monoblock arrangement. Is there really any advantage , :dunno:
skunark
Re: BP-27 Wish List
« Reply #17 on: 27 Sep 2011, 08:20 pm »
1.a With 12 volt HT bypass trigger that works when BP27 is in standby
7.   More detailed volume control
8.   A digital readout for the volume setting.
9.   Remote controlled power
10. RS-232 or IR input
11. All 12 volt triggers should use the much more common mini-jack
Would also like to see:
a. Modular DAC card that is at least dealer upgradable. i.e. two AES inputs, 1 AES 2 coax, 2 coax 2 digital.
b. Input trim
« Last Edit: 28 Sep 2011, 05:54 pm by skunark »
rollo
Re: BP-27 Wish List
« Reply #18 on: 28 Sep 2011, 01:55 pm »
  Just basically improve the power supply, all else is already there.  :thumb:
charles
SMA
rmurray
Re: BP-27 Wish List
« Reply #19 on: 28 Sep 2011, 03:37 pm »
 Realistically, James , are there any plans to alter or further evolve the bp26 in the near future.?  Thanks
