I need a stand mount that doesn't require a sub.
0 Members and 1 Guest are viewing this topic. Read 15502 times.
TKonrad.NOLA
« on: 7 Sep 2011, 10:25 pm »
Does Selah have a 2-way stand mount that punches above it's weight class?  Something that digs deep and makes you look for the hidden subwoofer?
kip_
Re: I need a stand mount that doesn't require a sub.
« Reply #1 on: 7 Sep 2011, 10:33 pm »
The Verita, Grandeur, SSR, and Tempesta all go down to below 40hz in room in ported cabinets. You're not going to find a small monitor that can go to true subwoofer depth (<30hz). It's simply impossible in a small cabinet. Hoffman's law says that you can't have high sensitivity, deep bass, and a small cabinet in the same speaker. Pick two.
neekomax
« Reply #2 on: 7 Sep 2011, 10:38 pm »
I've got a pair of monitors right here that say otherwise.  :wink:
http://www.audiocircle.com/index.php?topic=98017.0
http://www.audiocircle.com/index.php?topic=97955.0
ltr317
« Reply #3 on: 7 Sep 2011, 10:59 pm »
My AAD 2001 goes below 30 Hz, courtesy of Mr Phil Jones.
TKonrad.NOLA
« Reply #4 on: 7 Sep 2011, 11:30 pm »
I don't need true subwoofer bottom end, just incredibly good bass for a monitor.  38Hz-40Hz would be great.
wilsynet
« Reply #5 on: 8 Sep 2011, 12:58 am »
If you have $25,000 burning a hole in your pocket, the Magico Q1 was impressive at the California Audio Show.  Bass was phenomenal for a monitor, reaching down to 32 HZ.  Everything else about the speakers sounded great too, although I think that there are likely better values out there.
mcgsxr
« Reply #6 on: 8 Sep 2011, 01:11 am »
I agree that with a limited sized box, it is tough to hit low notes loud.
How much power do you have to drive the speakers, what sized room, and what type of music?
Some used Totem Mani-2's might work, but they LOVE power.
« Reply #7 on: 8 Sep 2011, 01:45 am »
The answer is to go active.  Incredible dynamics, flat frequency response, and unbelievably deep/full bass.  Look for companies that do active studio monitors and home speakers.  Unfortunatey these get quite pricey.
The new $1000/pair Soundfield Audio Monitor 1 is an interesting (and much cheaper) version of active standmounts (active bass/passive coaxial mid/tweeter that you'd use your own amp for):
http://soundfieldaudio.net/Home.html
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
« Reply #8 on: 8 Sep 2011, 01:52 am »
The ported versions of the Tempesta or Verita have excellent extension. By far the best bass (both quality and extension) of any 7" available.
kip_
« Reply #9 on: 8 Sep 2011, 02:06 am »
Where's the 8" subwoofer hiding in that design? That cabinet looks huge. Some Aether Audio (formerly SP Tech) designs do deep bass too, but with a ginormous cabinet.
kip_
« Reply #10 on: 8 Sep 2011, 02:07 am »
Also, the nearfield response is only 38hz, which isn't really any better than Selah designs. Room gain is highly dependant, on, duh, the room, as well as placement.
Rick Craig
  • Selah Audio
« Reply #11 on: 8 Sep 2011, 02:18 am »
Actually I couldn't find any nearfield curves - maybe you can point me to one? The amp driving the woofer can supply equalization so the amount of boost can affect headroom.
neekomax
« Reply #12 on: 8 Sep 2011, 02:18 am »
The cabinet is 17" high, 10" wide, and 12" deep. They are pretty heavy, owing to the large magnets in both the sealed sub and the coaxial mid/tweeter driver, about 35 lbs.
The bass is phenomenal, down to around 30 hz iirc. The sound in general is dynamic and smooth at the same time. You gotta hear them. A guy over at Audioholics is going to be comparing them to Revel Salon 2, Linkwitz Orion v3.2.1, KEF 201/2, all very expensive (and two way larger, floorstanding) speakers compared to the SAM1. Should be interesting.
The subwoofer is the lower driver, seen here:
neekomax
« Reply #13 on: 8 Sep 2011, 02:24 am »
Not sure if this covers what you're looking for...
Rick Craig
  • Selah Audio
« Reply #14 on: 8 Sep 2011, 02:35 am »
In-room curves are notoriously unreliable. A nearfield curve (or outdoor groundplane far away from buildings) will show the true extension. Since this is a sealed design it would be easy to test indoors with the microphone 1/4" away from the center of the cone.
kip_
« Reply #15 on: 8 Sep 2011, 02:36 am »
I was talking about the quoted figure on the website, not going by graphs. I am not knocking the speakers, I have no doubt they're a good speaker, but if you're talking bass extension, you either have to take room gain out of the equation or just guess based on someone's semi-mythical room if you want to compare apples to apples.
neekomax
« Reply #16 on: 8 Sep 2011, 02:42 am »
I believe that there were outdoor measurements taken and posted, but...
since the manufacturer is on this forum, I'll let him address the measurements if he wants to, as I'm not the one who did them. Just a satisfied customer  :).
Rick Craig
  • Selah Audio
« Reply #17 on: 8 Sep 2011, 02:48 am »
I love active speakers (my reference is always partially or fully active); however, active monitors have always been a tough sell in the audiophile market. In pro audio it's much different and they have almost universal acceptance. One potential problem is that some plate amps are bandwidth-limited and not good for powered monitors (depends where the crossover point is and the slope).
TKonrad.NOLA
« Reply #18 on: 8 Sep 2011, 03:10 am »
I owned a pair of speakers previously that had built in subs and it was a pain in the ass to deal with.  I will never go that route again.
Are those 2 Selah models built using the same cabinet?
Rick Craig
  • Selah Audio
« Reply #19 on: 8 Sep 2011, 03:12 am »
Yes - same cabinet.
