0 Members and 1 Guest are viewing this topic. Read 9658 times.
Omni-directionals typically radiate much of their energy (soundstage) up.
The Decware Radials (gen 1) used an upfiring mid/woofer and forward firing tweeter (that look similar in concept to those HR1's)
Interestingly if you follow that link you'll find that those RL3's have been replaced with the ERR (Extended Range Radial) that looks just like the 1st generation Decware Radial I heard (inverted main driver facing up/front firing ribbon with one cap/resistor).
In any event, none of the Decware Radials are bipoles.
In my opinion, the main advantage of bipolars set up correctly is a relatively well-energized, spectrally-correct, late-arriving reverberant field - and this is psychoacoustically desirable because it does a good job of recreating the feel of live music. Dipoles, omnis, and other polydirectional speakers do a good job of this as well.
Planet 10 (Dave): what happened to your post why can't bipoles go deep?
If the drivers in a bipole are tightly coupled the dramatic reduction in box load because of the active force cancellation also does not hurt the quality of the bass.dave
Please explain what you mean.
