Can you use a laptop as a remote for SB?
0 Members and 1 Guest are viewing this topic. Read 1779 times.
Pez
« on: 3 Sep 2011, 09:39 pm »
If my entire music library is located on my desktop is there a way to use my laptop as a remote using squeezebox remote? I tried a couple of things to make it work, but I'm still pretty novice at the inner workings of this wretched software.
edit: I do use iPhone and iPad via iPeng to control SB, which is wonderful, but I would like to be able to use my laptop if I've got it as well.  :thumb:
ted_b
Re: Can you use a laptop as a remote for SB?
« Reply #1 on: 3 Sep 2011, 10:12 pm »
I would think that pointing your laptop at the remote web interface would work, something like:  http://127.0.0.1:9000/
eclein
« Reply #2 on: 3 Sep 2011, 10:23 pm »
Pez....I know with some Browsers (Chrome I'm sure of) you can get a plug in that sits up in your browser until you click on it and a little remote, mini player will launch. My Squeezebox.com Remote Extension is the name of the plug in for Google's Chrome. I don't know if Firefox has one but most likely they do somewhere....
Pez
« Reply #3 on: 3 Sep 2011, 11:09 pm »
It works that way on safari as well. I think Ted may be on to something. I'll give the a try when I get back home.  :thumb:
eclein
« Reply #4 on: 3 Sep 2011, 11:41 pm »
Ted always gets the right answer...damn!!!....LOL :wink: :surrender:
firedog
« Reply #5 on: 4 Sep 2011, 10:09 am »
Yes, what Ted says should work. I've also done it.
lcrim
« Reply #6 on: 4 Sep 2011, 03:11 pm »
Ted's answer would only work if you are running Squeeze Box Server on that laptop as he has provided the so called "loop back" address.
The principle is that you can view Squeeze Box Server in a browser interface by supplying the IP address and the port (9000).  You alsp must be on the same subnet as the server.
This will work in Firefox as well as Internet Explorer.  This is not exactly news.
Larry
ted_b
« Reply #7 on: 4 Sep 2011, 03:18 pm »
Larry
Oops, that's right.  So, Larry, would adding the server's IP address work (from the laptop)?
lcrim
« Reply #8 on: 4 Sep 2011, 03:46 pm »
Ted:
The server's IP address (usually in the format 192.168.x.x:9000) will work.  I've noticed that some of the newer Linksys broadband routers provide a guest account for visitors that leases an address that is actually on a different subnet for improved security.
In my system, the pc running SBS, is in a different room to get all that noise, mechanical and electrical, away from the listening environment.
Larry
Pez
« Reply #9 on: 4 Sep 2011, 04:00 pm »
The IP address was not the issue, selecting the appropriate player was. Any way thanks for the help, it's up and running and I have yet one more nerdy way to control my SB.  :thumb:
