0 Members and 1 Guest are viewing this topic. Read 2530 times.
Hi, James. I think I read that the BDP-1s have been back-ordered since introduction. After placing a BDP-1 order with a dealer, approximately how long would it take to be fulfilled? Thanks in advance!
Hi,Usually 10 days to two weeks depending on colour and size.james
Size?I thought they're all the same size?
No.... as with most things they are bigger on this side of the pond. james
National debt?
Just to confirm, what options do you specify when placing an order? I'm assuming they are:1) Size (17" or 19");2) Face plate color (silver or black); and3) Display color (green or blue letters)Is this correct? Anything else?Thx in advance!
James,You can request either green or blue display on the BDP-1? If so, that is nice.Is that also available on the BDA-1?
