Refernce Recording Downloads
0 Members and 1 Guest are viewing this topic. Read 1917 times.
jjc1
« on: 24 Aug 2011, 08:07 pm »
  James, or anyone else out there, can Reference Recording downloads be downloaded to be put on a USB drive to be played with the BDP!?  If so, has anyone done this and how is it done?
BrysTony
Re: Refernce Recording Downloads
« Reply #1 on: 24 Aug 2011, 09:31 pm »
All of the Reference Recordings Catalog can be downloaded from HDTracks https://www.hdtracks.com/index.php?file=browse_music&type=label&id=16.  RR has a few HRx recordings in 176.4khz/24bit on DVD-R data discs that can be ordered directly from RR.  For those you just have to put the disc in your computer's DVD drive and copy it over to the BDP-1 drive.
Tony
rbbert
« Reply #2 on: 25 Aug 2011, 01:53 am »
Unfortunately, not all of the RR recordings are available at higher than CD (16/44.1) resolution at this time.
BrysTony
« Reply #3 on: 25 Aug 2011, 03:18 am »
That is true but you can always count on the RR recordings to be high quality and well done.
Tony
jjc1
« Reply #4 on: 25 Aug 2011, 01:59 pm »
Thanks for the tips. I didn't realize that RR downloads were on HDTracks. That's where I download most of my music.
Tony, when you rip a RR disc to a computer, will it be copied at 176/24?
BrysTony
« Reply #5 on: 25 Aug 2011, 04:54 pm »
jjc1,
The only discs that will give you 176/24 are the ones identified as HRx and sold on DVD-R data discs.  These discs will not play in a CD or DVD player.  They must be played through a computer.  I have purchased only one of these which is a terrific jazz recording.
Tony
jjc1
« Reply #6 on: 25 Aug 2011, 05:08 pm »
jjc1,
Tony
  Can they also be ripped to the computer?
srb
« Reply #7 on: 25 Aug 2011, 05:32 pm »
They are WAV files and can simply be copied to the hard drive.  Because they are WAV files, they will not contain metadata tags, so you should be able to use a metadata tagging program or your music player program to download the tags.
jjc1
« Reply #8 on: 25 Aug 2011, 05:50 pm »
  Thanks Steve.
             John
srb
« Reply #9 on: 25 Aug 2011, 06:46 pm »
I should have gone on to say that the standard WAV format cannot store tags in the file itself and that players like iTunes will store these tags in their own database.  If you want these files to have tags that will show in any music player software that you might use, you may want to convert them to AIFF.  (You could also convert them to FLAC if (a) you don't need to play them in iTunes or (b) if you are using the Pure Music iTunes add-in playback engine, which does support FLAC).
jjc1
« Reply #10 on: 25 Aug 2011, 06:52 pm »
  I just want to play them thru the BDP which plays wav files. I actually have some of my music in WAV which I play thru BDP.
