Pure Music Volume Control Settings
0 Members and 1 Guest are viewing this topic. Read 8510 times.
ted_b
Re: Pure Music Volume Control Settings
« Reply #20 on: 19 Aug 2011, 01:59 am »
I thought I've been in HOG mode all along...I guess not.  It will not let me select it.   :scratch:
Then either memory playback is not selected, or your DAC is still owned by Audio Midi.  Deselect it and choose "internal output"
jtwrace
    • TIPP YouTube Channel
« Reply #21 on: 19 Aug 2011, 02:01 am »
Tried it already...Memory play is selected.
ted_b
« Reply #22 on: 19 Aug 2011, 02:14 am »
Can u show screenshots of what I showed?  Is your DAC listed in the device list above the hog mode checkbox?
JohnR
« Reply #23 on: 19 Aug 2011, 03:04 am »
Umm, thanks John. As far as I can tell, that button merely enables/disables dithering. I was hearing that there was a button to disable volume control itself, but I think that there is none.
No - just set it to zero (if that's what you want)
jrebman
« Reply #24 on: 19 Aug 2011, 03:43 am »
Sorry guys, it appears that some of the control names I hear through VoiceOver are not what you guys see on the screen.  Rob and I  found ths out when he was remoted in and helping me find some of the controls -- btw, I have yet to try 1.8 as my system is down for upgrades and mods and building of a dedicated listening room, so I haven't checked out anything since 1.74a and maybe these controls are either no longer there or speak the same name now as the one you guys see on the screen -- Rob had said he would be making some changes as in addition to thisproblem there were many controls I wasn't seeing at all -- like hog mode support, a control to select the dac, etc. -- all pretty important stuff.
I'll be moving all my computers this weekend so I'll try the mini, upgrade PM and report  back with what I find.
Actually, I think you have to both -- disable dithering and set the output to 0 dB, or as Ted said, switch to integer mode.
-- Jim
jtwrace
« Reply #25 on: 19 Aug 2011, 07:52 pm »
I will try it again tonight or tomorrow if I'm not working.  If not, I will post some screen shots (if I can figure that out with Mac).   :duh:
jtwrace
« Reply #26 on: 20 Aug 2011, 01:05 pm »
How is this?
ted_b
« Reply #27 on: 20 Aug 2011, 09:55 pm »
Looks to be fine to me.   :scratch:  Are u saying u got it working?
jtwrace
« Reply #28 on: 20 Aug 2011, 09:56 pm »
I did it this a.m.
What I found out is that I had to "configure speakers" when deselecting my dac.
ted_b
« Reply #29 on: 20 Aug 2011, 10:00 pm »
Oh well, looks good now!    :thumb:  Can you discern a difference?  For me it was quite startling good.
jtwrace
« Reply #30 on: 20 Aug 2011, 10:09 pm »
I haven't really listened to it other then making sure it worked.  I've been busy working.
