0 Members and 1 Guest are viewing this topic. Read 17780 times.
I'm still a week away from buying MMG's and I'm struggling to wrap my head around... how DOES a planar make bass?Sure? You've got "all that surface area", but there's no X-max! How can you possibly get any bass out of a panel that barely moves? From what I understand, especially after the Magnestand mod, there's "lots" of bass, but I just can't comprehend how it's even possible to get any bass, even 200hz, from a flat panel.
the f110 just did mot blend well. it had output. but it lacked topend extension and tightness.
Go for the 3.7's and forget the sub. The step up in sound and detail in the 3.7 is too great to ignore. And the 3.7's put out a lot more bass, plus you will love the detail of that fully ribbon tweeter.
Jjay, another consideration that's not been mentioned is whether or not you've got a listening space with enough room for the 3.7's to perform well.
I also have a pair of MMG's and they have very good mid bass on their own and if you push them out to the corners of the room bass goes fairly deep, deeper than their rated 50Hz. I think that you will eventually find that you won't like the sound with the sub crossed high, it will sound muddy.
