0 Members and 1 Guest are viewing this topic. Read 2755 times.
You might try to solve this the other way round.The disadvantage of a single file is that you don’t have any information about the tracks.This can be solved using a cue-sheet.You might even “clue” the 2 sides together.Sites like http://www.regeert.nl/cuesheet/ or http://cuemaster.org/ allows you to manually lookup the recording in FreeDB and generates a cue sheet.This assumes:- There is a CD of this recording- Your media player supports cue-sheets.
Yes, it supports cue. I've got several albums recorded that way I listen to on my Touch. It also worked before 7.6
Medieval Cue splitter works perfectly for me. Well, aside from one album that was poorly ripped recently, it hasn't failed me in the 2 years I've used it. It purely splits the file and doesn't affect the sound in any way.http://www.medieval.it/cuesplitter-pc/menu-id-71.html
Are you saying this works with vinyl rips? Are there online cue sheets available for the original vinyl editions, or do you somehow make use of the cue sheets for CD editions?
