Question about sheilding
0 Members and 1 Guest are viewing this topic. Read 1082 times.
ebag4
« on: 10 Aug 2011, 07:47 pm »
When trying to electrically shield a device, say a transformer inside a preamp, does the metal shielding need to be grounded to the ground connection of the IEC to be effective?
I am thinking about lining a section of the chassis with copper sheeting and would like to know if that in itself will be effective in keeping electrical noise out of the audio ckts.
Best,
Ed
richidoo
Re: Question about sheilding
« Reply #1 on: 10 Aug 2011, 08:18 pm »
Depends on what frequency you are trying to shield. For stopping hum caused by magnetic inductance from transformer, you need something that is magnetically permeable, not copper. To shield from RF interference like AM radio then copper would work.
http://en.wikipedia.org/wiki/Electromagnetic_shielding
http://www.magnetic-shield.com
lounge Audio
« Reply #2 on: 11 Aug 2011, 01:06 am »
The basic answer is yes, ground the shield to the earth connection on the IEC connector.
Best Regards
Robert
ebag4
« Reply #3 on: 15 Aug 2011, 05:28 pm »
Thanks for the answers guys, I believe you have me pointed in the right diretion.
Best,
Ed
