BDP-1 Issue
0 Members and 1 Guest are viewing this topic. Read 6273 times.
Dilbert
BDP-1 Issue
« on: 4 Aug 2011, 04:47 pm »
Folks, I am sorry if this has been covered, but I can't see that has. Mind you, there is tons of onfo here to wade through :scratch:
I am slowly making progress getting into this whole digital music thing, but I am having great difficulty setting up an interface between my BDP and my PC.
I downloaded Firefox and then tried to download Minion, but I get a message that they aren't compatible. :o :duh:
Anyone else run into this?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP-1 Issue
« Reply #1 on: 4 Aug 2011, 04:51 pm »
HI,
Firefox 5 is incompatible with the current Minion but it will work on earlier versions of Firefox.  There should be an updated Minion which will work in 5 soon.
Try GNOME -
MEMO: BDP-1 INTERFACE
SUBJECT: GNOME MUSIC PLAYER CLIENT
December, 2010
Hi Folks,
Here is a link to a new free client for MPD that you can use with the Bryston BDP-1
Digital Player.
Tried it on my Windows 7 laptop and XP desktop with very good results interfacing with
the BDP-1.
http://gmpclient.org/installation
Just install the GMPC part 0.20.0
Dilbert
Re: BDP-1 Issue
« Reply #2 on: 4 Aug 2011, 05:01 pm »
Thanks James. Does it need Firefox, or can I use Explorer? That was a speedy response, by the way!
SHV
Re: BDP-1 Issue
« Reply #3 on: 4 Aug 2011, 05:25 pm »
Any recommendations for Mac/OSX?
Re: BDP-1 Issue
« Reply #4 on: 4 Aug 2011, 05:32 pm »
Nice thing about GNOME is it does not use a browser and connects directly to the BDP-1.
james
Re: BDP-1 Issue
« Reply #5 on: 4 Aug 2011, 05:33 pm »
Hi Steve,
I use Safari on my Mac Pro Laptop and also use an iTouch and iPad with the applications MPOD and MPAD
james
« Last Edit: 4 Aug 2011, 07:00 pm by James Tanner »
Dilbert
Re: BDP-1 Issue
« Reply #6 on: 4 Aug 2011, 05:36 pm »
james
Cool, thanks 8) 8) 8).
Dilbert
Re: BDP-1 Issue
« Reply #7 on: 4 Aug 2011, 05:46 pm »
Oh boy...I loaded Gnome but it's asking for all sorts of stuff like host information to connect? I guess I need to become a computer geek and leave the audio behind....
James, have you experienced this?
Re: BDP-1 Issue
« Reply #8 on: 4 Aug 2011, 06:06 pm »
Re: BDP-1 Issue
« Reply #9 on: 4 Aug 2011, 06:07 pm »
WBimmer
Re: BDP-1 Issue
« Reply #10 on: 5 Aug 2011, 11:48 pm »
I had the same issue at first and then after researching it a little, I found it that you need to make a small change to one of the program files and all is good.
Follow these instructions and all works fine.
http://stuff.thatblogs.com/content/music-player-minion-firefox-4-mpd-client
Wayne.
Dilbert
Re: BDP-1 Issue
« Reply #11 on: 6 Aug 2011, 04:50 pm »
Okay James, I got it going via ethernet to my desk top. Your help is greatly appreciated.
Now to get my laptop doing the same, wirelessly.... :?
Dilbert
Re: BDP-1 Issue
« Reply #12 on: 6 Aug 2011, 05:44 pm »
Success, lap top wirelessly enabled! Now, how the heck do I access the radio stations with Gnome? :scratch:
Dilbert
Re: BDP-1 Issue
« Reply #13 on: 8 Aug 2011, 03:48 pm »
James the only way I got my BDP-! to interact wirelessly with my latop was to create a secondary network with another router. This conflicts with my existing wireless network.
So, off I marched to my local Tiger Direct and bought an ethernet bridge. This can allow any ethernet based device to talk on an existing wireless network, just the ticket or so I thought....
It won't talk to my BDP-1, for some reason. Any idea what the problem could be?
« Last Edit: 8 Aug 2011, 06:05 pm by Dilbert »
Re: BDP-1 Issue
« Reply #14 on: 8 Aug 2011, 03:52 pm »
James the only way I got my BDP-! to interact wirelessly with my latop was to create a secondary network wits another router. This conflicts with my existing wireless network.
Over my head on that one - will ask engineering.
james
jjc1
Re: BDP-1 Issue
« Reply #15 on: 8 Aug 2011, 04:21 pm »
Hi DILBERT. This is how I got my local network BDP-1 connection to work.   I purchased a Netgear Powerline adapter kit. I simply connect one adapter to my router and then  into an electric outlet and connect the BDP-1 to the other adapter(which is plugged into an outlet near the BDP-1,which is in another room than my wireless adapter) via an ethernet wire. Now I am connected to my home network also.Did not have to get a separate router. Thru this setup, I can connect to all the BDP controllers (Bryston Mini,Max..Mpod, Mpad, Minion, Gnome). This also allows me to get Internet Radio thru the BDP-1 as well as art work, etc.
 Hope this helps.
Dilbert
Re: BDP-1 Issue
« Reply #16 on: 8 Aug 2011, 06:09 pm »
Thanks for the suggestion. I did see those power line based devices while at the store this morning. I would really rather not do it this way. But, ultimately, things just might swing this way. :cry:
The thing is that I can connect wirelessly to the Hawking 300N bridge, it just won't allow me to tlak to the BDP with Gnome or Firefox. Really strange. James I would appreciate anything you folks might suggest.
Meanwhile, I think a call into a call center in Calcutta is called for!  :green:
jjc1
Re: BDP-1 Issue
« Reply #17 on: 8 Aug 2011, 06:20 pm »
    If you are concerned about degradation of sound quality using the power line devices, I can assure that it has had no effect and the music from the BDP is superb.
Dilbert
Re: BDP-1 Issue
« Reply #18 on: 8 Aug 2011, 07:06 pm »
No not at all, I am just not crazy about putting more RF noise into the power line and there is the overall safety aspect. They kind of remind me of the old 5 tube ac/dc radios...with the chassis connected to one side of the line. :o
jjc1
Re: BDP-1 Issue
« Reply #19 on: 8 Aug 2011, 07:14 pm »
    I have all my audio equipment on a dedicated line. The adapter is on plugged into a completley separate circuit.
   As far as a safety issue, should I be concerned about my hose burning down due to electrical fire?
