Tube pre with solid state (class D) amp?
0 Members and 1 Guest are viewing this topic. Read 9583 times.
capwkidd
« on: 3 Aug 2011, 04:59 pm »
I was thinking about trying a tube pre amp with my D class SS amps.... Would this help give some tube mid/high warmth to the great bass I get from the class D amp? What do you think?
Big Red Machine
Re: Tube pre with solid state (class D) amp?
« Reply #1 on: 3 Aug 2011, 05:04 pm »
It's been done many times and works great.
bladesmith
  • water quenching steel since 2001....
    • palmer knives
« Reply #2 on: 3 Aug 2011, 05:14 pm »
I am experimenting with that right now...
zybar
« Reply #3 on: 3 Aug 2011, 06:18 pm »
Depends on what tube preamp is used.  Not all tube preamps excel at providing warmth and body.
What amps do you have?
What price range are you thinking for the tube preamp?
What features do you need on the preamp?
With more info, we can provide some suggestions.
George
twitch54
« Reply #4 on: 3 Aug 2011, 06:34 pm »
if mid / high warmth is what you seek why even use a Class 'D' amp in the first place ??
capwkidd
« Reply #5 on: 4 Aug 2011, 01:44 am »
Which preamp/amp are you using? Which speakers?
capwkidd
« Reply #6 on: 4 Aug 2011, 01:50 am »
- NuForce Ref 9 V2's
I am flexible.... $3k around..
Aluminum remote :)!
Not much... I don't even need more than 2 inputs, as I plan to just run a DAC into it. All my devices are digital...
George
NuForce Ref 9 V2's
Aluminum remote :)!
I am looking at the Primaluna Dialog Three and Cary SLP 98L
Then to figure out which DAC's!
capwkidd
« Reply #7 on: 4 Aug 2011, 01:51 am »
Theses are some of the best sounding "D class" amps I have heard. They are actually better sounding in the mid than the Pass X150 I had before them....
And of course they have an incredible bottom end to them....
What tube amp has SET mids with D class bass? None I suspect...
catastrofe
  • "That's what credit cards are for. . ."
« Reply #8 on: 4 Aug 2011, 02:25 am »
SAS Audio Labs B11A.  You won't regret it.
Bill Baker
    • Musica Bella Audio
« Reply #9 on: 4 Aug 2011, 02:58 am »
With the right combination, you could have everything you are looking for. Class D amps have come a long way and when paired with the right preamp, you would never think you were listening to a Class D amp.
capwkidd
« Reply #10 on: 4 Aug 2011, 04:57 am »
B11A? I found the 11A....
capwkidd
« Reply #11 on: 4 Aug 2011, 04:57 am »
Thanks for the encouragement :)
mfsoa
« Reply #12 on: 4 Aug 2011, 02:29 pm »
I am having good success with a VAC Standard MkII pre into a Digital Amp Co. Cherry Plus (high power Class D).
Best of both worlds...
-Mike
opnly bafld
« Reply #13 on: 5 Aug 2011, 12:10 am »
"B" (Basic $2849 shipped as opposed to "S" Standard $3049 shipped) has 3 line inputs ("S" has 5) and no tape loop or HT bypass.
A blemished 11A is currently available for $2600.
http://www.sasaudiolabs.com/specials.htm
Agree with catastrofe, great preamp.  :thumb:
10A is also very good (Basic $1595 Standard $1795).
Lin
watercourse
« Reply #14 on: 5 Aug 2011, 03:50 pm »
I'm having great luck with my Juicy Music Peach II with a Cherry Plus as well. Just be sure you get the impedance matching correct, otherwise you may limit bandwidth. With your NuForces, the input impedance is around 22K I believe.
The Cherry line has 10K input impedance, which is why I went for a tube pre with a switchable low output impedance (90 ohms), which helps it play well with many different amps with even low input impedances.
I've heard the X250, neutral but a touch on the warm side. I can see how a warm, tubey preamp with the Pass might sound too warm. May be down to the pre, actually, as what I've heard from the Pass amps provides your desired mid/high warmth. The NuForce 9s that I tried in my system was on the cool/thin side, especially in the highs and lower mids, which would likely be accentuated with a "light" sounding tube pre. This was my experience with the "light" sounding Dodd battery pre and the NuForces.
Disagree strongly that Class D amps can't be warm. Have heard a Tripath based amp sound overly warm in fact.
rajesh
  • Live & Let Live
« Reply #15 on: 5 Aug 2011, 05:02 pm »
Hey, your thread caught my attention right away. I have recently purchased a Tube preamp and SS Power amp combo. I intend to dust up my Class D power amp and pair it with the tube pre that I bought.
capwkidd
« Reply #16 on: 5 Aug 2011, 07:53 pm »
Ut oh! More equipment to try! Maybe I can get the Primaluna Dialog 3, Cary SLP 98L and the SAS 11A all in home at the same time :)
catastrofe
« Reply #17 on: 5 Aug 2011, 10:11 pm »
SAS has a 30 day trial. . .
Cheeseboy
« Reply #18 on: 8 Aug 2011, 03:02 pm »
Watercourse,
So the Juicy Music got the "Dark Side of the Mountain" going for you?  Glad it worked out.
bladesmith
    • palmer knives
« Reply #19 on: 8 Aug 2011, 04:36 pm »
Has anyone had any success with a hybrid power amp..?
(Maybe a hybrid amp with a built in tube line stage..)
