0 Members and 1 Guest are viewing this topic. Read 9597 times.
Ut oh! More equipment to try! Maybe I can get the Primaluna Dialog 3, Cary SLP 98L and the SAS 11A all in home at the same time
Steve,Got one with a remote for volume?
The Cherry line has 10K input impedance, which is why I went for a tube pre with a switchable low output impedance (90 ohms), which helps it play well with many different amps with even low input impedances.
Some teach a 100:1 ratio, ............Decreasing the ratio from 100:1 to 10:1 results in virtually no increase in harmonic distorion. For example if the total harmonic distortion at 2v rms output measures .01% (-80db) using the 100:1 ratio, changing to 10:1 raises the distortion by approximately .012% to -79db, a rise of approx 1db. Not much difference is it.Let's check for any high frequency response advantages vs preamplifier output impedance (Z). Assume amplifier input Z of 100k ohms (Preamplifier output Z mostly influences the high frequency response.) If one uses a high capacitance interconnect cable (IC) and include amplifier input capacitance, say 250pf of total capacitance, and the preamplifier/source output impedance rises from 100 ohms to 2000 ohms, the high frequency response drops approx 0.4db at 100,000 cycles per second, and approximately .015db at 20khz.Using a 50pf interconnect cable results in less than 0.02db drop at 100khz, and virtually zero at 20khz.
author=watercourse So then, all things (source>preamp>amp) being equal, I change my preamp setting from low Z to high Z, and I get a limited frequency range (both high and low freqs) with the amp with a 10K input impedance.
But when I do this with my amp that has 250K input impedance, all things held constant but change only the output Z of the preamp, I get no loss of frequency response. How would this be explained if combined Z of pre/source, as well as output coupling capacitors or output transformer don't change?
Steve,Sorry I was unclear. I was posting my actual observations of differences in amps with low and high input impedances, not theoretical.In my case, high output Z is 3.5K.Hopefully this discussion will be of help to the OP.Wilson
Well, I'm not going to argue with an electronics designer about things I'm not schooled in, however, I can say that my empirical observations are as I've posted. The variables are held constant except for the change in output stage (no change in output trannies or capacitors) from low output Z to high output Z, and there is an audible difference on a low input Z Class D amp, but not a high input Z tube amp.Any further particulars and I will have to contact the designer of my preamp and amps, and post their opinions.So, I would caution that let your ears be the judge.And I do believe this is all to help the OP learn about how to match tube pres with SS amps. So Capwkidd, just say the word and I will contact my peeps and get you more info.Wilson
Is there such a thing as an optimal impedance ratio? Or, all other things being equal and knowing nothing else but the input Z of the amplifier and the output Z of the pre-amplifier, is there a rule of thumb that should be used?I've heard 10:1, 20:1, now this thread mentions 100:1.
