Bryston Loudspeakers
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Loudspeakers
« Reply #2760 on: 4 Apr 2021, 07:07 pm »
Hi,
Is Moon Audio the best place to buy Bryston speakers if you don’t have a dealer in your area?
Hi King
Yes they have been very supportive of the speakers and have done very well with them.
James
kingcrowing
« Reply #2761 on: 4 Apr 2021, 07:16 pm »
James,
Thank you! One other question, is the TC-1 Mini actually 16.5” deep? It looks more square in the photos and says it’s 10.5” tall.
« Reply #2762 on: 4 Apr 2021, 07:35 pm »
James,
Here's a better picture for you.
kingcrowing
« Reply #2763 on: 4 Apr 2021, 07:55 pm »
James,
Ah that makes sense now. Is it possible for the speaker to be slightly tilted up (if placing lower than ideal) if leaned back or is it too front heavy?
« Reply #2764 on: 4 Apr 2021, 08:00 pm »
James,
You can tilt it up - one of the main design parameters of all our speakers is very wide dispersion both vertically and horizontally so there is a lot of flexibility in placement.  Think of it as a Flood light rather than a Spot light.
james
kingcrowing
« Reply #2765 on: 5 Apr 2021, 12:01 am »
James,
How would the AC-1 Mini pair sonically with the Middle T towers?
« Reply #2766 on: 5 Apr 2021, 12:11 am »
James,
Hi
Yes it is a perfect match as it has the exact same driver compliment.
james
« Reply #2768 on: 10 Apr 2021, 11:25 am »
SUBJECT: Bryston Surround System – Customer Feedback
April 2021
Hi James
I went to Mustansir's Bryston listening room with my colleague Andy Williams. We were pleasantly surprised and have to say, it is one of the best demo rooms I have ever been to. You can see a lot of effort has gone into the place.
The Bryston set-up blew us away.
Mustansir has definitely thought about catering for everyone's needs, from us audiophiles wanting the very best reproduction in sound, to individuals after that full surround sound, cinema experience.
My colleague knows Bryston quite well, but I had not actually heard a Bryston system before. I never realised how many products Bryston has in it's range.
I have to say, what I heard was better than I thought it would be. The sound was so detailed and true, across the full spectrum of the soundstage, layered and airy in a 3D manner.
I have already recommended a few people to go to the Bryston listening room in Dubai, so they can experience it for themselves.
I congratulate you for having such a fantastic facility, showcasing Bryston in Dubai/UAE, well done.
Regards
Max
« Reply #2769 on: 19 Apr 2021, 03:37 pm »
HI Folks
I know I am tooting my own horn here but I recently setup a pair of the Bryston Mini A speakers in my smaller RM 3 listening room.
You know it's one of those circumstances when the room just suits the speaker! I can not believe how great these thing sound in this room.  :thumb:
Anyway if you are looking for a small 3 way mini monitor that can fill a room and disappear please check these out!
james
Gumby
« Reply #2770 on: 19 Apr 2021, 04:31 pm »
Hi James
Which Stands are those with the Mini A’s?
What Source and Amps ?
Gumby
« Reply #2771 on: 19 Apr 2021, 04:35 pm »
James
Will the new partnership of Axiom and Bryston mean new Speaker models in the works?
« Reply #2772 on: 19 Apr 2021, 04:39 pm »
Hi James
Hi - They are Target stands.
I am using 7B's but I think the 3B or the 2.5B would be a great match in most setups.
james
« Reply #2773 on: 19 Apr 2021, 04:40 pm »
James
HI
Nothing in the works currently but we are always researching for ways to improve performance.
james
Soldeed
« Reply #2774 on: 22 Apr 2021, 12:59 pm »
James,
Hi
james
How well would the AC1 Center timbre match with the Model T?
Is the AC1's frequency response 25Hz-20kHz ±3dB as per the posted specs?
https://bryston.com/passive/a-centers/
« Reply #2775 on: 22 Apr 2021, 01:10 pm »
No I would not recommend the AC-1 for a Center unless most of your listening is to Stereo.  The AC-1 uses 6 1/2 inch woofers whereas the Model T uses 8 inch woofers.  So the power handling on the TC-1 center is a much better fit.
james
Soldeed
« Reply #2776 on: 22 Apr 2021, 02:56 pm »
james
I am 70% Stereo 30% Movies.  I am currently using an AC1 Micro but I would like to re-purpose it to another room with Mini A's. My Front Wides are Mini A's and Rear are On Walls.
I assumed the AC1 Center would be a better fit since it would compliment my surrounds.
Thoughts??
« Reply #2777 on: 22 Apr 2021, 03:46 pm »
Thoughts??
Hi
Yes given the use and the rest of the system the AC-1 should be fine.
james
« Reply #2779 on: 4 Aug 2021, 02:32 pm »
Hi James
I got a look at some large scale industry data and it said Bryston speakers account for 2% of global speaker sales over $5k.
Gary
