Bryston Loudspeakers
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Loudspeakers
« Reply #2720 on: 28 Mar 2020, 12:53 pm »
SUBJECT: Bryston Model A3 speaker – Customer Feedback
March 2020
Subject: Testimonial
Hi Folks,
I just wanted to let you know how unbelievable my Bryston A3 towers are.
Suspension of disbelief. Absolutely!
My speakers disappear during listening sessions. As the volume increases, the sound just gets better, more full.
I am so happy that I stepped into the Brystons! I cannot sing their praises enough.
Thank you for such a great “ entry “ level speaker! There is nothing missing in the music during playback. When comparing these to another brand, the difference in the Brystons ability to produce bass and the right treble is unbelievable.
Thank you!
Mark Kaminski
alexone
« Reply #2721 on: 2 Jun 2020, 09:51 am »
James,
Bryston doesn‘t offer port plugs for any type of  their speakers.
Why?
Thanx,
al.
« Reply #2722 on: 2 Jun 2020, 10:30 am »
James,
Why?
Thanx,
al.
Hi Al
Yes we do - in fact they come with the speakers.
Here is what they do at the low end as you add them on the Model T
alexone
« Reply #2723 on: 3 Jun 2020, 07:11 am »
...ah, ok! then i was wrong. it was just a thought because they are not to find on Bryston‘s website.
however, nice to know  :thumb:  so please allow me one question: how would a Middle T sound like with the plugs?
al.
« Reply #2724 on: 3 Jun 2020, 10:22 am »
al.
Hi Al
Using the plugs is really a matter of room integration. If the room does not support really low bass (boom or lack of transients) then you can use some or all of the plugs to tame and tailor the level of low bass in the room.
With all the plugs in as you can see from the graphs you get a gradual rolloff in the very low frequencies and the speaker behaves much like an acoustic suspension loading.
james
drummermitchell
« Reply #2725 on: 6 Jun 2020, 12:18 am »
Not to derail,is Bryston still shipping if acustomer places an order or are we held up for awhile.
« Reply #2726 on: 6 Jun 2020, 12:50 am »
Hi Drummer
We are back to work as of this week but heavily backordered so any new order is about 4 weeks out.
james
drummermitchell
« Reply #2727 on: 6 Jun 2020, 02:33 pm »
Thanks James,
I know Brystons web site is still in the works as when I try to down load the manual for the mini A wireless speakers,the 28 amp pops up.
Want to compare the Mini A with the Bryfi-2 for my deck.
« Reply #2728 on: 6 Jun 2020, 03:49 pm »
HI Drummer
Thanks will let the web guy know.
The BryFi has the same set of drivers as the Mini A so its more a decision of portability of a complete system versus  separate components.
I use the BryFi on my backyard deck during the summer and then as a kitchen radio in the winter.
james
drummermitchell
« Reply #2729 on: 12 Jun 2020, 04:19 pm »
Thanks James,
Is it possible to have a manual on the Bryfi-2 on here.
Curious as it does have mute and vol on the cabinet,can a person control vol from ph or IPad,
Thx
If it’s a month for delivery then I still have some summer left 8)
« Reply #2730 on: 12 Jun 2020, 05:02 pm »
Thanks James,
Thx
Hi
Yes it has volume controls and mute on the top of the unit and it also has its own GUI for control.
james
« Last Edit: 14 Jun 2020, 07:09 am by James Tanner »
domonly
« Reply #2731 on: 23 Jun 2020, 01:17 am »
Hi folks ! New here , also in the audiophile world hehe..
Anyways i need your advice , as a total rookie, theres so many components and options.. !
I just purchased a set of Bryston middle T cherry loudspeakers , a Bryston 4b3 cubed amplifier, and a Topping d90 Dac.
Now.. what kind of cables input/output would you suggest me with these components ? Its the very first audio system i buy, and im a bit lost haha.. should i also look for a pre-amp or it should be fine as it is ? Running a bit dry after all those purchases though .. ( student here )
appreciate any suggestions,
thank you !
Dom
Gumby
« Reply #2732 on: 23 Jul 2020, 09:09 pm »
I’m currently driving Bowers & Wilkins 707 standmounts with a Bryston B60.  Considering a change of sound. Does anyone have experience with The Mini A’s or Mini T’s  with the B60?   Would they be a good match or should I add more power?
gberger
  • Check 6
« Reply #2733 on: 24 Jul 2020, 01:57 am »
gumby,
I asked a similar question a few days ago; however, I'm only using FM as the signal source.
James Tanner responded. He is using a B60 with MiniA speakers in his office, and internet radio for music source.
He's satisfied, so that's good enough for me.
George
Gumby
« Reply #2734 on: 24 Jul 2020, 02:53 am »
Thanks for the info George.
gberger
  • Check 6
« Reply #2735 on: 18 Aug 2020, 11:35 pm »
James,
What is the backlog in Mini T and Mini A passive speakers?
George
« Reply #2736 on: 19 Aug 2020, 12:13 am »
James,
George
Hi George
Usually about 2 weeks from order unless its a standard colour then we may have it sooner.
james
gberger
  • Check 6
« Reply #2737 on: 19 Aug 2020, 02:03 am »
Thanks, James
BTW: That "Check 6" is old fighter pilot lingo for 'Check Your Rear!"
George
Christo22
« Reply #2738 on: 29 Aug 2020, 11:55 am »
James,
What are the options now with the MODEL Ts?
Passive and Active.
Is the passive can now be upgraded to active down the road?
Back a few years ago you needed the Signature with external Xovers to do so...
When you order a pair, do you need to specify.
I have 28b3 at home but would still like to keep options...
Is Walnut a standard color?
« Reply #2739 on: 29 Aug 2020, 12:04 pm »
James,
Passive and Active.
Hi
We discontinued the Signature version - think we still have a pair or two left - so just the Passive version going forward.
Walnut has been popular so we did make it a standard version.
james
