Bryston Loudspeakers
0 Members and 19 Guests are viewing this topic. Read 1423790 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Loudspeakers
« Reply #2540 on: 24 Apr 2017, 05:27 pm »
Alright.
I'm also using the long wall and I’m indeed at approx 6-7 feet from the drivers.
Just in case, I will make certain to ask for the PORT PLUGS.
And will play with my acoustic panels (absorption) setup.
Bottom line and if I read you well, you don’t see any problem going big with the MODEL T right?
Only the concern about bass but if you have the flexibility of placement and treatment you should be fine.
Let me know when you order and I will try to speed it up for you.
james
gene9p
« Reply #2541 on: 27 Apr 2017, 07:49 pm »
Still singing .......with apologies to Montreal fans and Ottawa fans shortly.... lol
« Reply #2542 on: 27 Apr 2017, 08:42 pm »
Wow - what a great setup !
james
yvolpe
« Reply #2543 on: 10 May 2017, 08:52 pm »
Hi
I'm the proud owner of a pair of A2. For a center channel which one is better for a tone match with the A2. The Ac1 mini or the Ac1 micro ?
Yves
« Reply #2544 on: 10 May 2017, 09:04 pm »
Hi
Yves
Hi Yves - the AC1 Mini.
How do you like the A2's?
james
yvolpe
« Reply #2545 on: 10 May 2017, 09:50 pm »
Thanks Mr. Tanner for your quick response. I like my A2 very much. Good base, large sound stage.I really enjoy them!
Yves
« Reply #2546 on: 10 May 2017, 10:48 pm »
Yves
Hi Yves
Great!  I think they are exceptional  :thumb:
James
NavyDoc
  • Virabus mari victoria
« Reply #2547 on: 14 May 2017, 05:29 pm »
James,
I have just started getting serious about two channel audio after several years of being sidetracked by home theater (now HT system is complete 7.2.4). I have been reading so many Bryston threads and reviews that it's all starting to blur.
Two quick questions. Will the Middle T be available active (nice name as I did polyoma virus research in grad school and the middle T gene was part of my dissertation)? Second, will Bryston be at Captal Audiofest this year?
« Reply #2548 on: 14 May 2017, 07:22 pm »
James,
Hi Steve
Yes we have had some demand for a Middle T Active and we just finished this last week writing the software for the Middle T in the anechoic chamber for the BAX crossover.
We are in Munich next week and LA the week (with the debut of the Active Middle T) then Rocky Mountain and Toronto in October.
james
NavyDoc
« Reply #2549 on: 14 May 2017, 11:25 pm »
Hi Steve
james
Thanks James, I think I will try to make AXPONA next year. An active Middle T could be one sweet speaker!
« Reply #2550 on: 14 May 2017, 11:40 pm »
Hi
Yes until you hear what a good Active system can do you do not know what your missing  :thumb:
james
NavyDoc
« Reply #2551 on: 14 May 2017, 11:52 pm »
Hi
james
I agree completely! My HT speakers are diy JBL/dbx/Crown three way active speakers, the sound in phenomenal. But for two channel system I want a level of refinement that only true expertise can deliver.
witchdoctor
« Reply #2552 on: 15 May 2017, 01:04 am »
Hi
james
I was really lucky when I was just getting into the hobby I read a really good review on a pair of active speakers and got a pair. Then I decided to go 5.1 and now 14.1, all active. Each speaker is individually biamped internally. I would have had to buy 28 channels of amplification with passive speakers to even begin to replicate this. If you have a choice go the active route :thumb:
You end up having more flexibility, not less and will save tons of cash on amps and speaker cables.
I was watching Roger Waters The Wall yesterday in Dolby Atmos. Playing it at concert levels was so incredibly lifelike. There is a scene near the end of the concert where "the wall" comes crashing down and with all of that power in the active system it was like an earthquake in a condo.
NavyDoc
« Reply #2553 on: 15 May 2017, 06:14 pm »
Three active Middle T's with four active Mini T's would be incredible. :o
witchdoctor
« Reply #2554 on: 15 May 2017, 08:26 pm »
+1 The Mini T already goes down to 33 hz, an active version would definitely go down below 30 hz giving it potential bass extension of a floor stander in a fairly small package.
NavyDoc
« Reply #2555 on: 5 Jun 2017, 05:14 pm »
James,
Will there be an active Mini T in the future?
« Reply #2556 on: 5 Jun 2017, 05:15 pm »
James,
HI
I am thinking about it depending on how things go with the Model T and Middle Active versions.
james
NavyDoc
« Reply #2557 on: 6 Jun 2017, 12:39 am »
HI
james
I hope they sell well for you. After building 3-way active speakers for home theater i just cannot go pack to inductors, resistors, and capacitors for signal shaping.
DogsPart2
« Reply #2558 on: 7 Jun 2017, 07:58 pm »
After all this time, all the accolades and all the research, I finally pulled the trigger on a new pair of Mini T speakers this afternoon.
THey received the wife's seal of approval from an aesthetic point of view. Looking forward to receiving them soon.
« Reply #2559 on: 7 Jun 2017, 08:30 pm »
Hi
That's great !!! :thumb:  I am sure they will live up to their billing.
james
