High quality DIY linear power supply for a SB Touch?
0 Members and 1 Guest are viewing this topic. Read 3358 times.
LewinskiH01
I read the Touch will improve significantly if used with a good linear power supply instead of the switchng supply that comes std. I know these things can be purchased in the US and Europe, but I live in Argentina and would like to explore the DIY route.
What makes for a good quality linear power supply?
Feel free to get technical and/or point to other sources, drawings, etc.
Horacio
mainscablesrus
    • Suppliers of Hi-Fi & Home Cinema Mains Items
Re: High quality DIY linear power supply for a SB Touch?
« Reply #1 on: 1 Oct 2011, 06:44 pm »
Horacio
you can get a made up psu for £100 from the UK, suggest that is easier than making your own?
Phil A
« Reply #2 on: 1 Oct 2011, 06:55 pm »
I just had one of these modded by Bolder Cable and am breaking it in (got it yesterday) - http://www.herbach.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HAR&Product_Code=TM93PWS2476&Category_Code=PWS
You need to buy two and I think it is under $30 with shipping.  It comes with the wrong connector (as part of their mod Bolder Cable changes the connector).  I'd think it would be an improvement over the stock PS.  I'm breaking it in and I also use power supplies that can fit the touch with HDMI audio-de-embedders (one in the main system and one in the secondary system).  Hopefully when this one gets broken in another Audio Circle member will bring over his Touch and we will compare the Bolder modded Jerome Unit, the Channel Islands and the Welbourne.  I'll keep the two best ones in the main system and use the other in the basement system on the HDMI audio de-embedder.
Sola, also makes a PS that would be suitable.  They sell the PS and cover separately at places like newark.com.  Sometimes you can find them cheaper on E-Bay.  Was also considering that route but have been too busy.  Going that route, one would need to connect a cable with the proper connector (which probably can be bought at places like Parts Express).
Phil A
« Reply #3 on: 1 Oct 2011, 06:57 pm »
If I had more time - this is what I might considering messing around with - http://www.solahevidutysales.com/pdf/powersupplies/SilverLine.pdf
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #4 on: 3 Oct 2011, 11:08 pm »
Not to toot my own horn, but look here. This same supply I built/designed will work for the Touch as well. This is a simple Ei Core transformer -> Full wave bridge Hexfred diodes -> Capacitor-> Choke -> Capacitor to get about 12 V DC pre regulated. Then that is connected to a Paul Hynes shunt regulator to get 5V DC regulated.
Best,
Anand.
Steidl Guitars
« Reply #5 on: 4 Oct 2011, 03:02 am »
I bought one of those for my Touch PS.
Now you're going to ask me how it sounds, and I have to admit that I never even tried the stock supply.  I know, very non-audiophile of me, but I've already got too many cables, tubes, amps, preamps, speakers to swap!
Seemed nicely made, though.
Anand, very nice!
Phil A
« Reply #6 on: 4 Oct 2011, 03:13 am »
We forgive the non-audiophile :green:  I'm breaking in a Bolder modded Jerome as noted above to be audiophile and compare three PS.  We'll see as I have power conditioning too if there is a difference I can hear
poseidonsvoice
« Reply #7 on: 4 Oct 2011, 03:21 am »
Anand, very nice!
No, this sir is very nice! Kudos to you!:
Moderator, Sorry for the OT.
Anand.
mjock3
« Reply #8 on: 15 Oct 2011, 01:23 pm »
Those are some real beauts!! Who makes those?
Mark
