Input from Bryston 9BSST users on heat dissipation?
0 Members and 1 Guest are viewing this topic. Read 5197 times.
Phil A
Re: Input from Bryston 9BSST users on heat dissipation?
« Reply #20 on: 12 Jul 2011, 09:21 pm »
Good reason I guess for keeping your amp cool.
That is interesting.  In all systems I try to take extra care in making sure things are well ventilated. For example in the basement I have the rack recessed into the wall.  The recess in in the unfinished space.  I cut away most of the ceiling above the rack in the picture below to allow for breathing room, a large portion of the space behind the components is open to allow one to get to cabling and increase air flow and I even drilled a bunch of 3/4 inch holes by the sides of the receiver in the back to also allow heat to escape.  I always figured the less heat around components the better.
BrysTony
« Reply #21 on: 12 Jul 2011, 09:32 pm »
Interestingly enough - I came across this review in Stereophile, where the footnote made specific mention of the impact of heat on capacitor life.  It states the following: "Footnote 1: Each time a filter capacitor's temperature is lowered by 5 degrees C, its operating life is doubled."
http://www.stereophile.com/solidpoweramps/725
Although I like the Stereophile magazine, everything in it is not correct.  That footnote is absolutely incorrect and not even close.  Here is a complicated reference for anyone that is interested that provides the reliability heat factors used by the US Military for reliability predictions.  Capacitor data is in section 10 and there is a heat factor table for temperatures.
http://www.quanterion.com/Publications/MIL-HDBK-217/MIL-HDBK-217F%20w%20N1%20and%20N2.pdf
Tony
