0 Members and 1 Guest are viewing this topic. Read 5204 times.
Thanks for the reply John.I have got the hiface working with Foobar although I think I may need to tweek the settings.
I purchased the hiface from Quang Chen who lives in Quebec.
Why is the Softsqueeze player not suitable for the hiface?...I have sent you a PM...
Ther are some settings such in the playback area likeDS Hiface or KS hiface , I was not sure which one to use, If I select Asio, I loose the sound...
also my computer settings to optimize playback...in XP the hiface was only selectable for recording and not playback..I have to select usb device to get it to work.
I can use the softsqueeze player via usb directly to the dac so I do not understand what a usb transport would do differently, I thought it would just be reclocking and allow higher resolution if desired...
Yes, the SqueezeBox protocols are completely open, so anyone can write a client and pretend to be a SqueezeBox device.Looks like he's talking about ASIO, but yeah, SoftSqueeze doesn't know how to talk to ASIO as noted by the thread I referenced.
(snip)...As for updating to win7 my computer is 3 yrs old and I have been told that I can't update from XP with my current intel quad core mother board
