F.S. Virtue Audio 2.2 with 130w power supply
0 Members and 1 Guest are viewing this topic. Read 3153 times.
HiFlight
« on: 11 Jun 2011, 10:57 pm »
I have for sale my "as new" Virtue 2.2 in black, as I have replaced it with the Virtue Sensation. I am the original purchaser of the amplifier and have owned it for about 7 months.  I have all of the original packaging, as well as one of the very scarce wooden volume knobs in addition to the stock chrome knob.  Both the stock 24v 60w power supply and the optional 30v 130w supply are included.  I also have both the red and silver logo badges.  Total cost of the 2.2 and 130w power supply new is about $650 with shipping.   I am asking $495 for the package.
I will ship anywhere in the US for a flat rate of $15.00
Thanks for reading!
Ron
Rclark
Re: F.S. Virtue Audio 2.2 with 130w power supply
« Reply #1 on: 11 Jun 2011, 11:15 pm »
That is a helluva deal!
Mass. Wine Guy
« Reply #2 on: 12 Jun 2011, 07:23 pm »
Please excuse my technical ignorance, but what is the per channel RMS output at 8 Ohms?
srb
« Reply #3 on: 12 Jun 2011, 07:59 pm »
Per the Virtue amp page (http://store.virtueaudio.com/SearchResults.asp?Cat=27), the Virtue TWO.2 (as well as the ONE.2 and Sensation), "Power is approximately half (44 wpc) into 8 ohms. With the 130w supply, you will achieve max output into 8 ohms."
eclein
« Reply #4 on: 12 Jun 2011, 08:07 pm »
I own a TWO.2 with the 130W power supply and it easily has powered all kinds of speakers with plenty of reserve. I use mine with a Piano M1 CD player and Squeezebox Duet running through a Grant Fidelity Tube DAC-09 that acts as a DAC/pre-amp and with a simple jumper change the TWO.2 is easily converted into a power amp only and sounds even better that way. Fantastic units in my opinion and will only get harder to find as time goes on and the Virtue Line expands...good luck with your sale!!
HiFlight
« Reply #5 on: 16 Jun 2011, 07:54 pm »
I received an email from Ben (Stealth714atYahoo.com) that I am unable to respond to as it is a "do not reply" from AudioCircle.   Ben, if you happen across this post, please email me directly:
HiFlight(at)hotmail.com
Ron
mamba315
« Reply #6 on: 16 Jun 2011, 08:17 pm »
Was the upgrade from 2.2 to Sensation a clear and noticeable jump on your 'phones?
HiFlight
« Reply #7 on: 16 Jun 2011, 09:50 pm »
Yes it was, but I think the differences were largely due to the fact that the Sensation has the Sonicaps with Platinum bypass whereas the 2.2 has the Auricaps which have a warmer SQ that is a bit less detailed.   I preferred the Sensation with the tube buffer active, as I can listen without fatigue.  Without the buffer active, the level of detail was sometimes more than I preferred with some types of music.
I think with the same brand of caps in both, the sound would be nearly the same.  Whether the same differences would be noticeable with speakers, I couldn't say, as I have only used both with my balanced phones.
Ron
JohnR
« Reply #8 on: 17 Jun 2011, 12:05 am »
The "reply-to field" should be set correctly - hitting "reply" in your email program should set the correct return address.
Unless it's a notification of a personal message : http://www.audiocircle.com/index.php?action=pm
HiFlight
« Reply #9 on: 18 Jun 2011, 11:33 pm »
Virtue 2.2 SOLD!
