Should a power bar be used or not?
0 Members and 1 Guest are viewing this topic. Read 1715 times.
smwick
« on: 6 Jun 2011, 04:26 am »
I have a monster power bar that my cdp is plugged into as well as the dac/pre.  The amp is plugged directly into the wall outlet.  I think Frank recommends the amp be directly plugged into a wall outlet.  Would it be better to plug the dac/pre directly into a wall outlet rather than the monster power bar?  With my old system I heard an improvement when I had the cdp plugged directly into a wall outlet, but I didn't have a separate dac at that time.  Your thoughts...
Minn Mark
Re: Should a power bar be used or not?
« Reply #1 on: 6 Jun 2011, 12:46 pm »
smwick,
I have tried both variations:Monster HTS power bar vs direct to wall outlet. In my system, I could not hear a difference. That being said, its important to note that I was using a single 20 amp circuit in my listenting room. I think one might have more noticable results using several circuits to isolate various system components. YMMV.
Mark
decal
« Reply #2 on: 6 Jun 2011, 03:17 pm »
Try both ways and decide for yourself. After all, you are the one listening to your system.  :dunno:
rollo
  • Rollo Audio Consulting -
« Reply #3 on: 6 Jun 2011, 03:47 pm »
  BRILLIANT !!!!!!!
charles
