0 Members and 1 Guest are viewing this topic. Read 7867 times.
Are any of these mods (wool, bracing, new tweeter, etc.) I keep reading about for the RM40's going to be implemented in future production pairs? Just curious.Michael
Interesting Eric...I used about 1lb in each of 40's. Since your RM/X's are much bigger, is it possible that you didn't use enough? Or, I guess I used too much! Anyway, I heard an immediate difference with the lambswool.George
Ditto as Zybar.... I heard an immeadiate change for the better. I do not know the size of the holes behind the RM/X's midrange, but I used about 1lb per RM40. I do remember thinking that my 40's now must sound closer to the Elixer's. Maybe it doesn't help the Elixers as much do to the different shape of the baffle????
The sound is suble ,but surely notable. Could just be the over hype thats been stated us, so there may be an anticlimax for yoy others.Surely you must at least notice the reduction in brightness.Extreme highs and mid to lower base is more articilate .
Ekovalsky, I too have fsts, what I meant in reduction in brightness is in the mid panels.I beieve this reduction in (overhang) , the better absorbtion of the back wave is the reason to the better clarity that is very evident to me.By the way ,I used vinal daming sheets as gaskets between mid panels.Their only about 1 millimeter thick . now perfectly flush with cabinets. the results to me are another step up. vacols are awsome!
