0 Members and 1 Guest are viewing this topic. Read 8027 times.
Jared,Just build a 1-way and avoid that issue. Hard to beat some of the most recent really good ones without spending illy money.dave
If you purchase a kit or design from Madisound, they can assemble the crossovers for you.https://www.madisound.com/store/index.php?cPath=35https://www.madisound.com/services/leap.php
The OP hopefully see's that there are a ton of options once you start to look at this stuff closer, the baffle thing alone allows reuse of the cabs for as many projects as you want. You can do some of these without soldering-my moment of clarity!!! LOL...I love options!!!
Honestly soldering is not that hard.
Using a copper sleeve and crimping is a good suggestion for those who can't solder.
see how many options you have, so dream it up baby!!!!
Ditto that."Cold solder" (crimping) is used without fail in many applications.More correctly it's "Cold Welding".
