0 Members and 1 Guest are viewing this topic. Read 8026 times.
Hi JaredThis one looks well designed and cheap. http://www.audioheuristics.org/projects_gallery/ER18DXT/ER18DXT.htmI like it because it uses quality, high value drivers, full measurements are shown, exact parts listed and priced, and it uses low order crossover filters.If you build them please let me listen! P.S. Selah also sells kits.
You say you have no experience. Do you have any woodworking experience? Do you know how to read a crossover schemetic and solder it up? Do you have any test equipment to verify correct wiring and final results?Just asking because some 'kits' require more skill than others.
Skills are over rated. Jump in. It ain't rocket science.
I have never soldered or built a crossover. I do have a little experience reading wiring schematics but that was just in college for a few months in physics, I'd like to pick it up as I go and start with something simple and increase the the difficulty as I feel comfortable. If you want to recommend some test equipment I am all eyes and ears. I have a small amount of woodworking experience so I can make a box, it just wont be really pretty, but that is ok for now.
I have never soldered or built a crossover. I do have a little experience reading wiring schematics but that was just in college for a few months in physics, I'd like to pick it up as I go and start with something simple and increase the the difficulty as I feel comfortable. If you want to recommend some test equipment I am all eyes and ears. I have a small amount of woodworking experience so I can make a box, it just wont be really pretty, but that is ok for now.I wanna start out cheap that way if I mess up I am not out alot of money, plus I can sell them to friends for whatever they cost and eventually step up if I enjoy the process.I have a router and I am looking to get a nice table saw, hopefully a used cabinet saw that way I am good for the rest of my life.ThanksJared
You can also get by without a table saw- just take your measurements to your local Home Depot and pay the extra $.50 per cut to have them cut out the pieces.
Your Home Depot's lumber department is better than mine. When I had pieces cut, the tolerance was about +/- 3/32" which meant two pieces could vary by as much as 3/16" - not good enough for many projects. Steve
No, putting together a kit isn't hard. But designing stuff from scratch requires proper tools...
