Preamp to use with Khartago
0 Members and 1 Guest are viewing this topic. Read 3211 times.
alienderivative
« on: 28 May 2011, 12:26 am »
I would welcome suggestions for a reasonably priced preamp to use with the stereo Khartago.
smata67
Re: Preamp to use with Khartago
« Reply #1 on: 28 May 2011, 12:55 am »
Would it be a problem for you if the preamp came with an annoying hum?
bunky
« Reply #2 on: 28 May 2011, 01:00 am »
Do Tell  :scratch:
lazydays
« Reply #3 on: 28 May 2011, 05:03 pm »
Do Tell  :scratch:
well if you don't have a lot of money (less than $700), and want something fairly clean; I'd look for a Conrad Johnson 10al or a 10B. They really are not bad sounding, and have more inputs than you'll probably ever use. Another to look at is the Quicksilver linstage. Similar in concept to the CJ, but think the CJ is slightly more transparent. Once in awhile you'll see a Candella in the $800 range. The Candella has more presence and bass than the other two, but lacks a tape loop with three inputs. Stay away from the Chinese junk!
gary
TomS
« Reply #4 on: 28 May 2011, 06:26 pm »
This Mapletree would be really nice and also reasonable.
http://www.audiocircle.com/index.php?topic=93617.0
alienderivative
« Reply #5 on: 29 May 2011, 12:36 am »
Thanks, I appreciate the feedback.  I got into Eico tubes last spring after having the khartago as my original goal.  After that diversion, I need to sell several pieces of vintage gear before I can afford to make a move so that will give me time to research your suggestions.  I never would have thought of a couple of them so I really appreciate the feedback.
