0 Members and 1 Guest are viewing this topic. Read 5025 times.
If it looks clean but the vinyl is a little dull then it generally sounds dull, probably played on a poor rig in the past - I keep away.Look for "spider" marks around the spindle hole - lots of these tend to indicate many plays - Again I tend to avoid unless it's a long yearned for item or very well priced.Obvious one is avoid anything that is visibly scratched, regardless of how minor they might appear - generally even the slightest of scratches causes pops.Finally - don't be too frightened of dirty discs that are scratch free - this tends to happen if they have been sitting around for a long while, many of which may be unplayed. These can be cleaned - check out the many threads on this (my method is identified in my web page).
Two comments about vinyl that looks dull. Some vinyl IS dull looking as made. The biggest all the time dull is Telefunken. Various other LP manufacturers used a dull looking vinyl formulation.Then the opposite problem: LPs that are really 'shiney'. They have been treated with a silicone tire shine or such, and are atificially shined up. They are easy to spot once you know what they look like, as they are just too shiney!IMO the sort of dull to watch out for is the uneven ones. where the innertracks are dulller than the outer ones. THOSE are the worrn out records. Also watch out for DJ damaged LPs. Those have a single couple of inches of groove scratched up. Like used by the DJs 'scratching' back and forth. Plenty of those at some used places. (some used places will not even have any like that, as they do not buy them, or discard them from collections they buy.)
6. An old plastic arm Garrard turntable with a broken osmium stylus and a quarter taped to the arm for sale right next to the records!
If the place will not take back used LPs, they are scumbags, selling stuff they KNOW is bad. I wish i could barf on command on these guys! (I want to say all sorts of bad words) I have just told them to get the Hell away in that 'i will kill you' voice.I hate hate hate these people.
Has anyone had this happen. I pulled out the LP and it was beautiful went home cleaned it and then I am playing the LPwhen I realize it's the wrong record altogether. I never bothered to see if the LP matched the cover This is why I need a side kick to follow behind to make sure I don't screw up .........Bill
