0 Members and 1 Guest are viewing this topic. Read 3921 times.
I predict you will need just a little bass boost, but will be so amazed at the difference having no room makes that you will happily live with less bass until you can find a way to compensate. A decent (below 500Hz) bass control might do it. This type of turnover frequency usually only is found in devices with three tone controls - bass, mid and HF. Two control types typically use 1000Hz as a turnover frequency, which you might find is too high.I also predict that you might hear image specificity in the bass for the first time - I know I did. I didn't know it was possible to hear exact placement of a drum with a fundamental frequency of around 40Hz until I heard the recording outside (with small transmission line speakers of my own design).If you like good imaging, you will love the outside sound and will really hear, to your frustration, just what the room does to the sound of your system.Another big surprise was how realistically inside acoustics of venues like theaters can be represented. There is a stronger sensation of being "in" a particular space.Your biggest surprise might be how much you learn from the experience!
You clearly have no clue whats going on. Have you ever been to an outdoor concert? Thats a serious question because from your post i don't think you have. There is absolutely no chance of decent bass response unless you are up against the front of the speakers and those need to be driving some pretty big woofers. He is not going to get any bass response and you are not going to get form and accuracy from a bass drum off a pair of paradigm v20 outside (even thought they are good). Thanks for posting this, i get the pic now.
