BDP-1 Random Function
0 Members and 1 Guest are viewing this topic. Read 1492 times.
WBimmer
« on: 8 May 2011, 06:46 pm »
Can we play our albums or directories randomly??
I've tried pushing the random button on the remote and nothing happens and I can only get everything to play sequentially.
A random function would be very nice for all levels of directory.
Wayne.
Alpha10
Re: BDP-1 Random Function
« Reply #1 on: 8 May 2011, 07:00 pm »
If you have access to the Mpod interface, you can set it up such that when you shake the iPod it will play 25/50/100 random tracks, works great.
Not sure if any other interfaces offer anything like this?
Cheers
WBimmer
« Reply #2 on: 8 May 2011, 07:19 pm »
Currently I'm only using the BDP as stand-a-lone, so can it be done without using a network connection??
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 8 May 2011, 07:26 pm »
Hi,
No sorry - things like random and such are a function of the interface not the BDP-1.
james
WBimmer
« Reply #4 on: 8 May 2011, 07:50 pm »
Hi,
james
That's too bad.  I'd like to recommend adding it to a future software upgrade.
Thanks.
