Odyssey Candela Remote ?
0 Members and 1 Guest are viewing this topic. Read 2522 times.
Gvt1911
« on: 3 May 2011, 06:56 pm »
Can anyone advise if replacement remote controls are available? I have the MULTI function remote that came with the Candela, but was hoping for something more simple and smaller.
BobC
Re: Odyssey Candela Remote ?
« Reply #1 on: 3 May 2011, 07:22 pm »
Last time I complained about the remote to Klaus I was told there are 2 versions: one is the Symphonic Line "multi function" remote you mention....and another is reported to be a simple cheap black 2 botton remote for volume.
I not a fan of either.  I'd love to see the Kismet pre come with a really nice, full feature remote designed specifically for the unit.
In parallel, I've considered a universal.  For kicks I looked up Odyssey compatibility and it is listed in the online Logitech Harmony database....so it looks like that could be an option...but havent tried it out.
Charles Xavier
« Reply #2 on: 3 May 2011, 08:27 pm »
Works great with my Harmony remote
BobC
« Reply #3 on: 3 May 2011, 08:31 pm »
Good to know! :thumb:
klaus@odyssey
« Reply #4 on: 6 May 2011, 07:13 am »
No codes.  Has to be learning remote
Gvt1911
« Reply #5 on: 6 May 2011, 11:58 am »
Klaus,
Do you have a 2 button remote for the Candela?
