0 Members and 1 Guest are viewing this topic. Read 14868 times.
Channel Islands makes a device especially suited for filtering DC, and it's not terribly expensive.Good luck.Peace,Tom E
The manufacturer suggested buying a humbuster to reduce the noise and I purchased this problem and set it up in my system but to no avail the buzzing persisted.RegardsRod
Seems that you made a bad buying decision, so you get little sympathy here. It's true that any dealer or manufacturer should stand behind their product better than this one has. Why did you buy an untrialed $5k amp when there is no warranty coverage locally? No equipment is worth that kind of risk, especially if you're not rich.
I just couldn't bring myself to type anything like this^^^^^^knowing that the opening poster would read it eventually.But hey I could be wrong....Good luck...Ed
