0 Members and 1 Guest are viewing this topic. Read 23096 times.
I've heard some atmasphere amps a couple of times and thought they sounded nothing like sets. They had some qualities that were better than SETs and some qualities that were no where near as good as the better SET amps. Personally, I'd lean toward the SET amps (done right, most aren't).
OP doesn't seem interested
The SS amp with the most tube like sound I have heard is the ModWright KWA 150. http://www.modwright.com/products/6 I liked it so much that I bought one.FWIW, several reviewers have made the same assessment. Bob Levi of PFO had this to say:And in his TAS review, Dick Olsher concluded:The KWA 150 is definitely worth a listen IMO.
Has anyone heard any of Tim de Paravicini's SS designs? Thoughts?
I suppose if your gear is in a constant state of flux then you might come away with some of those observations. Here's my take :- solid state is fluffier and fuzzier- solid state sound is intrinsic to its sloppy speaker control- heavy doses of measurable perfection make solid state sound like electronic equipment and not like music- to work properly solid state needs the right speakers
I have heard First Watt and owned Pass...neither remotely made me think that I was listening to a SET amp.That said, my SET amps continue to collect dust in the corner as I refuse to stop using my Atma-Sphere OTL amps. For me, the Atma-Sphere amps give me the liquidity, warmth, and texture of the SET amp with the detail, speed, and impact of a SS amp. Only drawback is the heat and electrical cost.George
The Valvet A3.5 is very similar in the midrange to the Airtight 211 SET but by comparison, a bigger bottom (+) but recessed highs (-) It's got a very fluid midrange but it's a bit syrupy which I like. 2a3s are quick and nimble so I don't think I would compare it to that. WE 300Bs a little bit but definitely more in line with 845s if I were to choose a particular tube.
I have and it is fantastic! At least my Tim de Paravicini designed Alchemist Forseti APD20A "Signature" is. My system bristles with synergy with it tethered to my Sunny H2W10 speakers. By far best sound I've had - smooth, open, dynamic, weighty, liquid, halographic, and naturally detailed. Great solidity, coherence and flow to the sound, resulting in real nice pace and timing. The clarity in the midrange is spooky at times. The thing blooms and decays and images/stages/layers like a good tube amp. Matter of fact, it's better than many tube amps I've heard! Draws you in and compels you to listen. No electronic artifacts, grit, grain or glare whatsoever. I have never heard SS like this -- NEVER! Quite satisfying. And that's coming from a confirmed-dyed-in-the-wool - toobaholic for the past 15 years. So for you oldsters out there, as Barretta used to say: "you can take dat to da bank!"
I meant anyone else and any other de Paravicini amp, John.
