0 Members and 1 Guest are viewing this topic. Read 2979 times.
What combos have you found that have a synergy. I've found using a V-cap TFTF as the input coupling cap and a Jensen PIO for the output coulping [ Alum. body] works very well. Using two V-caps was a bit to much Teflon sound. The Jensen brought the body back. Curious as to your experiences.charles
charles, try the V-Cap cu. They're excellent and ime different from, and complementary to, the TFTF sound you're wanting to moderate.
It produces very neutral sound, transparent, almost nothing (like direct coupling). But some people don’t like this kind of ‘sterile’ sound. Not analog, some people complaint.
3. of no distinctive quality, characteristics, or type; indifferent1. Not aligned with, supporting, or favoring either side in a war, dispute, or contest.2. Belonging to neither side in a controversy: on neutral ground.6. Physicsb. Of or relating to a particle, object, or system that has a net electric charge of zero.
The tone of the Jensen PIO is seductive but veiled compared to V-cap.
Would caps upgrades with sources like CD players be as significant?
