Any experience with Anti-cables IC's as phono interconnect?
0 Members and 1 Guest are viewing this topic. Read 1460 times.
Minn Mark
Am looking at these:
www.anticables.com
to connect my VPI Classic to phono inputs on my pre-amp. Any experience or impressions are appreciated.
Mark
Wayner
Re: Any experience with Anti-cables IC's as phono interconnect?
« Reply #1 on: 20 Apr 2011, 08:40 pm »
There isn't any shielding, so you may have hum issues. How about some nice Bluejeans cables instead? I think you will have a real good antenna for picking up local radio stations on your new VPI.
Wayner
Minn Mark
« Reply #2 on: 20 Apr 2011, 08:43 pm »
Thanks, Wayner.
BJ are on my short list as well. Have you used them as phono IC's?
PS- stupid question I know, but on their (Bluejeans) website are the IC prices for ONE, or for a stereo PAIR of IC's?
Thanks a bunch,
Mark
Wayner
« Reply #3 on: 20 Apr 2011, 08:49 pm »
I'm using them right now as I type, listening to Genesis, A Trick of the Tail on MOFI. Most excellent!
Wayner  :D
TheChairGuy
« Reply #4 on: 21 Apr 2011, 02:49 am »
www.anticables.com
Mark
I prefer unshielded cables on line level devices.  If they add any noise, it's not distracting and the sound is better to me - un shielded.
However, with TT's (and I have a VPI Classic, as well) - they need shielded IC's the hum and noise is horrific, otherwise.  As Wayner indicated, don't get anything but shielded for your VPI
John
rif
  • Not a cowboy
« Reply #5 on: 21 Apr 2011, 03:19 am »
I'm using bj cable (their custom stuff bj1?) from my vpi hw19 to my phono inputs. Grado platinum cart. No hum. I'm not even using the grounding connection from tt to preamp. Maybe I just got lucky. Did I just curse Myself? Ugh
