BDA-1 output voltage
0 Members and 1 Guest are viewing this topic. Read 1595 times.
Charles Calkins
« on: 12 Apr 2011, 04:03 pm »
I've read on Audio Advisor BDA-1 spec sheet that output voltage is 2.3V Unbalanced and 4.6V Balanced. How come a difference in output voltage?
                                            Cheers
                                          Charlie
Phil A
Re: BDA-1 output voltage
« Reply #1 on: 12 Apr 2011, 04:13 pm »
Not an engineer but this is a good read - see top of page 6 - http://focus.ti.com/lit/an/sloa054d/sloa054d.pdf
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 12 Apr 2011, 04:41 pm »
                                            Cheers
                                          Charlie
Hi Charlie,
The voltage doubles when you use a Balanced (XLR) output as compared to a single ended output (RCA).
james
Charles Calkins
« Reply #3 on: 12 Apr 2011, 05:29 pm »
Mr. Tanner:
 Here is the dumb question of the day. I'm thinking if I use the Balanced outs to a pre the music will play louder than using the Unbalanced outs to a pre.
                                                      Cheers
                                                     Charlie
« Reply #4 on: 12 Apr 2011, 05:38 pm »
Mr. Tanner:
                                                      Cheers
                                                     Charlie
Hi Charlie,
There are no dumb questions just dumb answers :lol:
Correct if the sending and receiving components are both balanced then you will have 6dB more gain (level).  The Bryston amplifiers have a GAIN control switch on the back though that allows you to reduce that gain by 6dB if you wish.
james
Charles Calkins
« Reply #5 on: 12 Apr 2011, 05:44 pm »
Mr. Tanner:
 Second dumb question of the day. I see that vendors are selling XLR to RCA cables. If I used them would I get the 6db gain even though my pre has Unbalanced inputs only.
                                           Cheers
                                           Charlie
« Reply #6 on: 12 Apr 2011, 05:51 pm »
Mr. Tanner:
                                           Cheers
                                           Charlie
Hi Charlie,
No - both ends have to be Balanced to get the extra gain.
james
Charles Calkins
« Reply #7 on: 12 Apr 2011, 06:02 pm »
Mr. Tanner:
   Thank you. No more dumb questions today. Maybe tomorrow.
                                           Cheers
                                            Charlie
