Reflektor 6H30-DP tubes --- SOLD
0 Members and 1 Guest are viewing this topic. Read 3312 times.
zeke
« on: 6 Apr 2011, 02:10 am »
These are the 6h30 supertubes from Parts Connexion. They are a matched pair . I bought these in Nov 2010. I have sold the gear using these tubes.
they have been used ONE HOUR !  --- simply to test that they worked.
They are $99 each, new from Parts Connexion at this time.
$120 plus shipping for the pair.
zeke
« Last Edit: 13 Apr 2011, 03:46 pm by zeke »
zeke
Re: Reflektor 6H30-DP tubes
« Reply #1 on: 6 Apr 2011, 05:43 am »
I emailed Parts connexion asking if DP tubes are the same as DR tubes.
They replied that pre 1991 tubes may be labeled DR or DP --- same tube .................
zeke
Atlplasma
  • Just off the boat
« Reply #2 on: 6 Apr 2011, 09:23 am »
Hi Zeke. I'm interested in these tubes.
jtsnead
« Reply #3 on: 6 Apr 2011, 12:26 pm »
Steve,
If you dont want both I will take one
JT
jtwrace
    • TIPP YouTube Channel
« Reply #4 on: 6 Apr 2011, 12:38 pm »
are these supposed to be that good?
Atlplasma
  • Just off the boat
« Reply #5 on: 6 Apr 2011, 12:42 pm »
Steve,
JT
One would be fine. To answer jtwrace, it seems to add more bass and nuance to my Dodd buffer compared to a 12AX7. I have a tube, but it has developed some issues. (My fault and not the tube BTW.)
Levi
« Reply #6 on: 6 Apr 2011, 12:44 pm »
It is good providing the circuit is optimized to use it. The 6H30-DR is the best.  I have 8 of them in my BAT preamplifier and another 16 as spares. :)
JoshK
« Reply #7 on: 6 Apr 2011, 03:23 pm »
That makes sense, as the 12ax7 is a really poor choice for a buffer tube.  I am not suprised you get better bass with the 6h30. the 12ax7 has no current and therefore no real drive.
Atlplasma
  • Just off the boat
« Reply #8 on: 6 Apr 2011, 05:31 pm »
True. 1.89 watts versus 5.2 watts.
zeke
« Reply #9 on: 6 Apr 2011, 05:31 pm »
sale pending on these tubes  ........
but i will post if the sale does not go thru
thanx for all the interest
zeke
