0 Members and 1 Guest are viewing this topic. Read 27879 times.
Ok- Here's the info: and from Bill Firebaugh to my ears, not my opinion, etc..The tone arm gets 100,000 cSt 100% silicone. The main bearing originally got "Dow Corning 200 Fluid" which I believe is 50 cSt silicone, based on looking at the Dow Corning site. Now Firebaugh uses synthetic motor oil for the main bearing and says that exact viscosity is not critical- this is for both the earlier 'tables and the current ones. He says the synthetic motor oil works at least as well and is easily obtained.The vial of silicone shown in the link above looks a bit small and seems aimed at use for a tone arm. One vial might or might not be enough material for the cup on a WTL tone arm. With respect to using other fluids for the tone arm, Firebaugh sorted out a long time ago what works. I'd suggest using the correct fluid and adjusting damping as needed. Is that it? Let me know if any of that needs clarification.Mike
I know this is a really old thread, but hopefully some of you folks are still around and monitor this forum. After the disaster of moving my turntable (the movers constructed a very solid, well padded crate, then proceeded to turn it on its side so all fluids ran everywhere), the local turntable shop in my new locale repaired it. They used 120,000 molecular weight silicone, which appears to have the correct viscosity of 100 cst, but it is really thick--like warm creamy peanut butter thick.http://www.ofna.com/acc-fluids.htmlMy question is: I am getting wildly varying VTF readings (1.60 g - 2.1 g) using a digital balance depending on how the arm is moved into position to take the measurement, i.e. the damping fluid in the cup seems to have a significant effect on VTF. The fluid level is barely over the paddle. I've tried submerging the paddle lower and the effect seems to be worse (plus I don't like the sound as much), and raising the paddle such that the top is above the surface (the sides are still submerged) doesn't help.Has anyone else seen this? Should I try lower viscosity fluid in the cup? Evan
Hi Evan,I'm not sure what's happening in the first part of your question. The i.e. part is a most definite yes. Sounds like your paddle is close to right. Do not submerge it- you've found out how damped down it sounds then, to me very blah. The arm should have a certain feel, or drop, if you will, when it's right. One thing to start with that I haven't seen mentioned on here is to get a lined index card, put it on a record which is on the platter, and align the tonearm to be parallel with the index lines. That'll be a good place to start. Good luck!
The 100,000 is very thick. If I were you I'd wipe it all out and start over. As Mr P has stated time and time again, Mr F has figured all this out for us. Deviate at your own peril. Yes. Paddle, ball, your big toe, everything in the middle. If that's off you might as well own a VPI. And regarding damping, once all is filled, and centered correctly, then it's your cup that you adjust, by ear. Get that Allen key out. Again, after your arm is parallel, etc . Get the real goo. That Aussie goo sounds bad from here.
