Where to get fluid for Well Tempered Arm Classic?
threadkiller
Re: Where to get fluid for Well Tempered Arm Classic?
« Reply #20 on: 21 Feb 2016, 05:47 am »
Oh sorry. YOURE confused? Me, too, I thought you were Daveyontyecoast. All these broken old table threads are hard to keep straight.
Do exactly what Firebaugh says.
I had no VTF variant. My tables are set up correctly from the get go. I'm sure if you use the correct fluid you'll be fine as well. Or at least headed in the right direction.
I'll leave you to it.
ACHiPo
« Reply #21 on: 21 Feb 2016, 07:10 am »
 :scratch:
:scratch:
 :roll:
sHERO
« Reply #22 on: 9 Mar 2023, 03:39 pm »
The viscosity of 5w30 oil is 12.5 cST.
