0 Members and 1 Guest are viewing this topic. Read 6420 times.
Emotiva claimed (and still does) that the XDA-1 DAC's USB input has 24/192 capability but I found that to not be true. On that DAC, when using a true known native file output chain (Foobar > WASAPI) I was unable to play greater than 16/48 through the USB input.
I'm afraid specs often need some close readinghttp://emotiva.com/xda1.shtm says that the DAC is 24/192.This is probably true for the DAC (the chip set)They don't say anything about the inputs.My rule of the thumb: if nothing is stated explicitly about the USB assuming it is 16/48 max is a save bet
At least I know that everything up to that USB port is at least 24/96 on those particular files so the signal is there...
We got ASIO going...I think...LOL,,,I'll check under the hood
I'll check both things--hey Lee!!!But first I have found a website that says it has 24/96 Radiohead album and all I get is 16/44...
OK, try this, if you are on a Windows machine, go to "control panel", then "sounds", the select your device, then hit the drop down menu, if you see this, you have a 16/44.1 or 16/48 kHz device:Does that help? Or, as usual, am I off track?
