0 Members and 1 Guest are viewing this topic. Read 8977 times.
My current phono stage has been in my system since 1979-1980. It has been updated twice by the manufacturer for rediculous low money. I haven't really been looking to change it out, but I have heard other preamps that couldn't replace it........and they were a lot more money. The biggest issue I had with the others is the amount of background noise added. Some were very sweet sounding.......the VanAlstine modded ARC SP3-A1 was glorious in richness......I just couldn't take the tube "hiss" any longer. Which really isn't noticed, until you hear a completely silent pre.
This should be good and silent...and great sounding!http://www.audiocircle.com/index.php?topic=92610.0
I'm not so sure that I would agree that a MM "should have" 50-56 db of gain or a MC stage 70 db of gain.
Phono Stage is as important as anything else in the system. You have to match performance/price/type for the music that you listen to. It's a fun journey and there is no right or wrong answer. I am down to 2 systems that are different because I couldn't narrow it down to one to cover all of the music I listen to.
