Help me design a new 2ch system...
0 Members and 1 Guest are viewing this topic. Read 1609 times.
Christof
« on: 29 Mar 2004, 02:19 am »
Hey folks,
I'm in the process of building a new 2Ch system for my home.  I want to stay SS with this new system.  My current system is 2Ch SET and is being moved into my studio.
My foundation for this new system:
BPT BP-2ultra conditioner
ZU cables
Cryotweak silver wires
I'm building a pair of Linus 2 arrays from Selah Audio
Twin front firing Dymax Subs w/ Sonic Craft 12" drivers
Norh CD-1
I want to Bi-amp the Linus2 arrays.  I also plan to use the two subs in stereo.   Does this mean I need 6 monoblocks?  I'm looking for creative budget minded solutions.   I'm not opposed to used gear.  I should also say that I listen to a very ecclectic mix of music and often at fairly high volume levels.
Thanks for any input...
C.
JoshK
« Reply #1 on: 29 Mar 2004, 03:05 am »
Remind me what the efficieny of the Linus 2 array is?  Pretty high if I remember correctly.  Which is to say that if you choose to go SS with this system, you don't need a lot of watts but the first watt is critical.  If you are handy/DIYer then I would probably look to build gain clone(s).  You can start by looking at a recent thread here in the lab.
If you aren't handy Scott Nixon provides a finished product that is based on similar design.  There are others as well.  These won't cost too much and provide good amplification from what I have read.
I assume you need a preamp too?  IRD Purist is a great choice and even provides two sets of indepently buffered preouts.   You might start by passive biamping and look to active biamping later on, as an upgrade option.   I might even start with just single amping, then passive biamping then active.  For the sub, if it isn't powered then you will need an amp for the subs, which I might look at the pro audio market for inexpensive amplification since it isn't as critical in the sub region.
JoshK
« Reply #2 on: 29 Mar 2004, 03:08 am »
actually for even more budget minded solutions, check out the threads on the griffin powerwave.  2 channels of amplification for $99 and it supposedly sounds good too.
Christof
« Reply #3 on: 29 Mar 2004, 04:56 am »
Josh
thx for the advice.  I do need a pre as well.  The Linus 2 are around 95db.  I would rather go high than low W with my amplification.  I eventually would like to build Seas Excel Arrays which are much lower @ 88db.
I just read the review of the IRD MB-100 amp posted by Earlmarc and think this might fit the bill.
Anyone have input on this amp?  Earlmarc speaks a good word about it.
earlmarc
« Reply #4 on: 29 Mar 2004, 04:50 pm »
The IRD-MB100 would work well especially if you are considering purchasing the IRD-Audio Purist preamp. If I were in your shoes, I would strectch my budget and purchase the Odyssey Khartago.
Christof
« Reply #5 on: 31 Mar 2004, 04:26 am »
Just a though...
I have this:
ZU cables
Norh CD-1
add this:
Sherbourn 7/2100 7 channel amp
Stereo Sonic Craft 12" subs
Berhinger DCX2496 for the subs
Linus II mains
any input?
Thx C.
