IronKey USB drives on BDP-1?
0 Members and 1 Guest are viewing this topic. Read 1608 times.
miatadan
« on: 28 Mar 2011, 05:11 pm »
I found out that the Iron Key flash USB drives use SLC memory in S200 series but noticed this:
When an IronKey drive is plugged into a laptop
or desktop computer, the user must authenticate
with a password before encryption keys are
enabled and data and applications are accessible. Unlike software-based encryption, the
IronKey Cryptochip does not export AES encryption keys to the host PC, thereby protecting
against cold-boot and malware attacks.
will these IronKey be useable on the BDP1?
see this link
https://www.ironkey.com/files/datasheets/ironkey-basic-s200.pdf
Dan
  • The Demo is Everything!
    • http://www.bryston.com
Re: IronKey USB drives on BDP-1?
« Reply #1 on: 28 Mar 2011, 05:23 pm »
Hi Dan,
That's a new one on me - will ask engineering.
james
miatadan
« Reply #2 on: 28 Mar 2011, 05:24 pm »
Hi Dan,
james
just added link to my post James if you want more info
« Reply #3 on: 29 Mar 2011, 03:11 pm »
Hi Dan,
My software engineer wanted to know why you wanted to use this particular drive as your paying a lot for the encryption chip? Is it the SLC chip you prefer over MLC?
james
miatadan
« Reply #4 on: 30 Mar 2011, 12:31 am »
Hi Dan,
james
I do not care about the encryption chip at all. From research I have done these are the only SLC memory flash usb drives on the market now. Other companies has dropped SLC all together in USB flash drives.  I would purchase the Basic S200 series, not the more expensive Personal or Enterprise series.
Dan
« Reply #5 on: 30 Mar 2011, 12:59 am »
Dan
So are you assuming the SLC would sound better or just the longer read/write capability?
james
miatadan
« Reply #6 on: 30 Mar 2011, 01:03 am »
longer read/write plus longer life in general, not sure if there be any effect on sound
Dan
« Reply #7 on: 30 Mar 2011, 02:08 am »
Dan
Hi Dan
Without trying one i can not be 100% but I see no reason why the drives should not work just fine. Also I would recommend reformatting the key to fat32 if you do have any issues.
james
« Last Edit: 30 Mar 2011, 10:54 am by James Tanner »
