0 Members and 1 Guest are viewing this topic. Read 12744 times.
Hi,Sounds like fun. The mounting distance and hole size for the Rega is 222mm spindle to mounting hole center. I believe the hole is 3/4". Some people move this up to around 219mm to achieve a more desirable cart alignment. The arm is actually a little longer than 9". Many 9" arms are mounted at 211mm, the standard Linn geometry. They have an effective length of 229mm. I have no idea what the mounting distance or hole size is for the JMW. I'm sure you could find out easily enough without removing your arm. Just call VPI. Good luck with your new table. I love the look of those. Sounds like a terrific score. BTW, the Maestro is a MM cart, unless they made some radical change. neo
hallo,from what i have heard, the VPI tonearms and the Rega tonearms use the same mounting distance and hole size.not that it matters, as the VPI tonearms are considerably better. Rega RB 300 and RB 250 are just budget arms and no where near the quality of the VPI.if you prefer a gimbal bearing, take a look at the Jelco 370 series tonearms. they use the same 222mm mounting distance and are not to sneeze at.regards,bas
Gruetzi Bas! Ich spreche ein bischen Deutsch, aber nicht Schwietzer Duutsch. Schwietzer Duutsch ist sehr musikalisch!Bas thanks for your post. I agree that the RB250 as well as the RB300 are generally entry level tonearms, however the Incognito Rewire (from clips to connectors) and the Origin Live Mod (armtube and counterweight) really make the RB300 much better. Several companies have used the RB250 & RB300 as their base to create higher end tonearms. As in the case of the Swiss ETA 2824 watch movement, which is basic, high quality and fairly entry level, it can be turned into something extremely special. The modified RB300 on my Nottingham TT is considerably better than stock... maybe not as good as the VPI JMW 9!? There are a lot of tonearms that are much better. Tonearm and table matching are important too. Anyway, as long as the music is good! Best regards.
i got an original Live Arm with original wiring which is look identical to RB250,what kinda of Modification i can do to it make really sing :)without breaking the bank.I'm thinking buying a Terres DIY turntable ,would this be a good match or should i buy better arm for this turntable.Thank youlapsan
Thanks for the specs, Neo. I'll put them to use. Since the JMW 9 is already mounted, it won't be difficult to measure from the spindle to the uni-pivot. BTW, the Clearaudio Maestro is listed by Clearaudio as a "Moving Iron Cartridge" as opposed to a Moving Magnet. Moving Iron is standard on Clearaudio's Virtuoso and Masestro Cartridges... no radical change that I know of.Again, thanks for your post!
I guess all you have to do check the hole size cause mounting distance is the same? I'm not sure which Origin Live arm you have, the OL-1? It's said to be much better than a Rega, but I have no idea how much better. The more expensive Origin arms are well thought of. Whatever it is, it should be an interesting comparison. Please let us know what you think.You must have been looking at a distributors web site, or maybe a typo. All the Clearaudio HO carts are moving magnets. They're made by Audio Technica. There's a thread a few pages back about stylus replacement and its distant cousin, the AT-95. http://www.clearaudio.de/Click on products, then click on tonabnehmer.neo
just for a point of reference - o-l says their modded rb250 is better than even their modded rb900, due to bearing configuration. so, if you are looking for a good modded rega arm w/o too much expenditure, stick to the rb250.doug s.
Of course they'd say that. Do you think they might have a bit of a financial interest?But why would anyone get a Rega arm, even modified, when a Jelco SA-750D is a better arm at a better price?
Halo Bas,Just curious... what's your opinion about the Graham Robin? I understand that it's basically a 9" tonearm and a drop-in replacement for the Rega. Any thoughts? Best regards.
