Rega RB300 & VPI JMW 9 Tonearms
0 Members and 1 Guest are viewing this topic. Read 12746 times.
orthobiz
Re: Rega RB300 & VPI JMW 9 Tonearms
« Reply #20 on: 28 Mar 2011, 09:03 pm »
But why would anyone get a Rega arm, even modified, when a Jelco SA-750D is a better arm at a better price?
But isn't the Jelco mounted at 214/215? Wouldn't be a drop-in replacement then.
Paul
bastlnut
  • just make my jaw drop!!!!!
« Reply #21 on: 28 Mar 2011, 09:15 pm »
Paul
hallo,
rega and VPI, and Graham use 222mm mounting distance.
so no, it is not a drop in replacement.
the Jelco is ok, but i would take a Rega RB700 over one.
then again i would buy the Graham Robin instead.
it is a Jelco derivative but many improvements and the correct length.
the Jelco SA 370 is the same mounting distance as the Rega/VPI
besides, i prefer the lighter tonearm.
regards,
bas
