Custom made crossover PCB - Made in Vietnam !
0 Members and 1 Guest are viewing this topic. Read 15255 times.
Danny Richie
Re: Custom made crossover PCB - Made in Vietnam !
« Reply #40 on: 3 Apr 2011, 12:04 am »
Keeping them at right angles is more ideal.
Voncarlos
  • OB5s in Stripes
« Reply #41 on: 3 Apr 2011, 02:08 am »
I took the pictures of your board and laid them out in Photoshop, then arranged things to show you what folks are talking about. It's quick and dirty but it should work. The other components can be laid out anyway you want but this is how I would do the coils, as long as they are far enough apart.
Guy 13
« Reply #42 on: 3 Apr 2011, 07:29 am »
Hi voncarlos, Danny and all Audio Circle members.
Thanks for showing me your re-worked arrangement of my Made in Vietnam crossover PCB.
I will apply your re-arrangement/layout on my next PCB, because now it's too much work for me.
However, for the next one, the technician will do whatever arrangement I want.
Thanks again for your help, the next one should be 99.99999% perfect !
Guy 13
mikeeastman
« Reply #43 on: 4 May 2011, 11:49 am »
I rebuilt my x-over for my OB7s, here is before and after pics, are the coils oriented in the right directions now?
Before
After
S Clark
« Reply #44 on: 4 May 2011, 03:16 pm »
The only improvement that I see would be to rotate the bottom right coil 90 degrees to reduce interaction with the upper right coil.  What you want to avoid it interaction of the magnetic field.  Coils have field lobes that extend out of either end of the hole in a lobe pattern, much like an hour glass.  You want to avoid having the field lobes aligned, but if they must overlap, have them overlap at 90 degree angles instead of along the same plane.
Scott
« Last Edit: 4 May 2011, 04:25 pm by S Clark »
mikeeastman
« Reply #45 on: 4 May 2011, 04:05 pm »
Thank you Scott
NeilT
« Reply #46 on: 4 May 2011, 08:28 pm »
Hi Mike,
Could turn all the upright coils to face the middle one.
Neil
ebag4
« Reply #47 on: 4 May 2011, 08:38 pm »
Hi Mike,
Neil
x2
Best,
Ed
