Keep your "NUTS" tight!!!
0 Members and 1 Guest are viewing this topic. Read 2129 times.
John Casler
« on: 28 Mar 2004, 03:41 am »
Just a word to the wise, using your fingers will not do the job :nono:
John Casler
« Reply #1 on: 28 Mar 2004, 03:42 am »
:o  :o  :o  :o  :o  :o  :o  :o
:lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:
John Casler
« Reply #2 on: 28 Mar 2004, 03:45 am »
Of course I meant the nuts on your speaker binding posts.
If you are running any kind of speaker cable at all, with spade connections, it is very important to "tighten" the binding nut with a wrench.
Not so hard you strip the threads, but you'll probably be very surprised that they aren't really tight, if all you used was your fingers.
And we all know what "loose nuts" can do :mrgreen:
zybar
« Reply #3 on: 28 Mar 2004, 04:33 am »
What's worse than a loose nut?
A busted nut!!!  So don't over do it.
 :rotflmao:
George
jimbop
« Reply #4 on: 28 Mar 2004, 05:31 am »
I've tried spade connectors with numerous amps and speakers, and always found that the connection would loosen easily, even after wrench-tightening. I've gone to using Audioquest banana plugs on my speaker cables, and they always fit extremely well.
Tonto Yoder
« Reply #5 on: 28 Mar 2004, 10:27 am »
Quote from: John Casler
Loose nuts sink ships????
Or was that "loose lips"??  Nevermind.
StevenACNJ
« Reply #6 on: 28 Mar 2004, 04:34 pm »
I have a habit of finger tightening my nuts every morning  :oops:
John Casler
« Reply #7 on: 28 Mar 2004, 06:31 pm »
Quote from: StevenACNJ
Finger tightened nuts = a loose cable :nono:  :mrgreen:  :mrgreen:
And no one wants a "loose cable" :evil:
ekovalsky
« Reply #8 on: 28 Mar 2004, 08:32 pm »
I supposed your speakers are veneered in "Morning Wood"
 :lol:  :lol:  :lol:
mcrespo71
« Reply #9 on: 28 Mar 2004, 08:39 pm »
You guys are cracking me up!
Rob Babcock
« Reply #10 on: 28 Mar 2004, 09:04 pm »
But be careful- messing with your nuts too much can cause the sound to get overly "hard," sometimes almost "steely." :lol:
Ulas
« Reply #11 on: 28 Mar 2004, 10:18 pm »
Quote from: Rob Babcock
It's no joke. The theory I read, which sounds as plausible, or implausible, as any other audio theory goes like this. If the metal at the junction is highly compressed, many electrons are trapped in the distorted crystal matrix and cannot participate in conducting the electric current. Connectors should be only tight enough to make a good electrical contact. That usually means finger tight.
John Casler
« Reply #12 on: 28 Mar 2004, 11:47 pm »
Wow..that sound like "impotent" stuff :o
