Squeezebox Duet for $169 - DEAL ALERT
0 Members and 1 Guest are viewing this topic. Read 2946 times.
nocrapman
« on: 19 Mar 2011, 01:07 pm »
Amazon is selling the Duet BNIB for an awesome price. I know all of u r thinking, why get it over the overhyped (IMO) TOUCH. I have all 3 - SB3/DUET and TOUCH and prefer this for its form factor, inconspicuousness,  and ease of use! I use outboard DACs anyway... all I need is a digital stream and with an aftermarket PS - the DUET does it well!
Here's the Linky: http://www.amazon.com/Logitech-Squeezebox-Wi-Fi-Internet-Radio/dp/B0013IWYHU/ref=br_lf_m_1000667221_1_1_ttl?ie=UTF8&m=ATVPDKIKX0DER&s=electronics&pf_rd_p=1291495882&pf_rd_s=center-2&pf_rd_t=1401&pf_rd_i=1000667221&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1RAGG4Q31Z621GNX3FBT
mfsoa
Re: Squeezebox Duet for $169 - DEAL ALERT
« Reply #1 on: 19 Mar 2011, 01:48 pm »
Just bought 2, Thanks!
bahorn1
« Reply #2 on: 19 Mar 2011, 02:21 pm »
Thanks!  I already have a Duet.  But I just ordered the Squeezebox Boom from Amazon.  It also is $170 and has a $35 mail-in rebate if ordering from Amazon today.
etcarroll
« Reply #3 on: 19 Mar 2011, 03:46 pm »
Thanks for the 'heads-up', been trying to acquire just another receiver for the bedroom system, at this price it's like the handheld is for free.
HAITIMAN
« Reply #4 on: 19 Mar 2011, 05:00 pm »
will this work as a remote for my SB Touch?
etcarroll
« Reply #5 on: 19 Mar 2011, 05:14 pm »
Nope - I just dl the coupon for rebate, it's for 3 different items, but the Duet isn't one of them.
TJHUB
« Reply #6 on: 19 Mar 2011, 05:35 pm »
Yes.
bunky
« Reply #7 on: 19 Mar 2011, 05:48 pm »
i just bought one. i dont have a clue how to set it up  :scratch: is it pretty easy ?
etcarroll
« Reply #8 on: 19 Mar 2011, 05:59 pm »
It should be, but as with anything, there may be a glitch. How are you with diagnosing wifi issues?
Quickstart guide here, if no glitches, this is all you need to do to get up and running;
http://www.logitech.com/images/support/14901.1.0.pdf
Don_S
« Reply #9 on: 19 Mar 2011, 06:05 pm »
If I was able to set up the original SB via wifi you should have no problem.  :lol:  I do prefer the performance with the new Cat5e cable I recently installed.  Fewer dropout and reconnect issues.  I can't comment on the sound since I had the SB out of my system for quite a while and made a lot of changes. I do think the wired installation works smoother and connects and changes stations faster. I am using it for internet radio only.
nocrapman
« Reply #10 on: 19 Mar 2011, 06:46 pm »
It is pretty straightforward.
You do need a wifi connection or a hardwired one.
If you run into any issues, call tech support. They are very helpful, at least were back when I called them 2 years ago.
The remote is versatile and will control any of their devices. You can also sync different unit to play the same songs.
If u r tech savy, you can use your ipad or iphone with an app to control the units instead of the remotes.
You can see I am a huge fan.
That boom is an incredible deal. For $135 its a steal. I bought it for $199.00 only 5 months ago from Amazon.
Sam-fi
« Reply #11 on: 19 Mar 2011, 07:51 pm »
I can't believe I bought one. What an impulse buy? I saved about $130, I think. I saw that it did flac and then hit the buy button. I hope for the best with this purchase.
Sam
2wo
« Reply #12 on: 19 Mar 2011, 09:47 pm »
I can't find the boom for that price. Do you have a link?
jeffh
« Reply #13 on: 19 Mar 2011, 10:20 pm »
looks like the deal is gone..... :(
Don_S
« Reply #14 on: 21 Mar 2011, 05:15 pm »
Yes, bummer. Looks like the deal is finished.  I just found out my friend's older model SB failed.  I wanted to send him some good news. If someone finds a hot deal on SBs again I hope they will post it here.
