0 Members and 1 Guest are viewing this topic. Read 3250 times.
I read about these and they appear to be a cheap upgrade, but only if they work. Has anyone tried them?
One of the best, inexpensive tweaks. Apart from ground loops, there isn't anything that will make such a difference / improvement for the money. Highly recommended!
Sounds very fine. Do you have to use the pads with speakers grilles off?
Unless the manufacturer specifically states that the speaker was voiced with the grilles on, for critical listening it's best to leave them off. This product should make a positive difference either way, but I'm sure Jim could provide you with the best answer.
