Bryston Remote
0 Members and 1 Guest are viewing this topic. Read 4486 times.
audioman999
Bryston Remote
« on: 13 Mar 2011, 12:27 am »
What range is the remote supposed to have.  i changed the batteries but need to be 3-4ft in front of my B100SST for it to work.  is this a common problem?  any suggestions?
Diamond Dog
Re: Bryston Remote
« Reply #1 on: 13 Mar 2011, 04:20 am »
Same here with my BR2. Could it be.....
Gremlins...?
D.D.
95Dyna
Re: Bryston Remote
« Reply #2 on: 15 Mar 2011, 03:12 am »
Agreed.  Somthing isn't right.  I have line of site across 2 rooms to the BP26 and can change the volume or mute it without a problem.
Elizabeth
Re: Bryston Remote
« Reply #3 on: 15 Mar 2011, 03:18 am »
My Bryston BP-26 volume knob is within my left hand reach without effort, when seated in my listening chair.
I have the audio rack a bit out into the room at my left, with the powerline conditioners behind it. (So it is also easy to fiddle with the wiring)
Lazy you bet! I have the remote, but it sits unused on the shelf.  :sleep:
Ilkatze
Re: Bryston Remote
« Reply #4 on: 15 Mar 2011, 03:36 am »
My remote works fine in terms of range.  I'd like to take a small liberty to add another issue to this thread's topic.
The problem I have is with the "5 key".  You have to press *hard* to get it to engage, and it makes a snap sound (as if it were a snap-type button on an article of clothing).  It'll be fine for a few seconds, but then can require another very hard press after as little as a minute, and most always after around five minutes.  No liquid, glue, or anything else has ever been spilled on it.
rhart
Re: Bryston Remote
« Reply #5 on: 13 Jan 2012, 03:51 am »
I just bought a used B100 and have this issue as well. The guy who sold it to me had Bryston fix issue in October, but it looks like the problem has returned.
James, any ideas about this?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Remote
« Reply #6 on: 13 Jan 2012, 03:05 pm »
Sorry no - I have not come across this before but it sounds like the button should be replaced.
james
ralph1950
Re: Bryston Remote
« Reply #7 on: 15 Jan 2012, 04:15 pm »
I had this problem once with another remote.  I found that the button was sticking to the remote on the rim of the button on the inside.  Take the remote apart & clean it with some denatured  alcohol.  At least that worked for me.  Good luck!
sfraser
Re: Bryston Remote
« Reply #8 on: 15 Jan 2012, 06:30 pm »
I have to say my SP1 remote is the best of my whole lot. 20' feet away on an angle no problem....some times it works just by thinking about it  :thumb:
rhart
Re: Bryston Remote
« Reply #9 on: 15 Jan 2012, 08:49 pm »
Thanks. I'll give the remote a good cleaning and see if that helps.
redbook
  • the music is the blood...........
Re: Bryston Remote
« Reply #10 on: 16 Jan 2012, 12:06 am »
 It's been two years of daily use but my BR2 remote hasn't missed a beat with the BCD1. Can't say for the bda or preamp, don't have them (yet). I do find that the battery life isn't as good as the remote with my BP25. That is still on the original cell for the last ten years. The BR2 would have been nicer with the 9v battery. :scratch:
ralph1950
Re: Bryston Remote
« Reply #11 on: 16 Jan 2012, 06:06 pm »
Let us know if the cleaning helps.
rhart
Re: Bryston Remote
« Reply #12 on: 26 Jan 2012, 02:55 am »
Just wanted to report that my remote is now working just fine after a little cleaning and a new set of batteries.
ralph1950
Re: Bryston Remote
« Reply #13 on: 26 Jan 2012, 08:02 pm »
Good to hear the problem has been reversed!
alexone
Re: Bryston Remote
« Reply #14 on: 26 Jan 2012, 08:07 pm »
...just added the remote codes (from the Logitech data base) of the BDP-1 to my Logitech Harmony One remote :wink:
al.
