Audio/Video Gear and Systems
Owner's Circles
Channel Islands Audio Owners
CIAudio
DAC & passive driving 5k?
0 Members and 1 Guest are viewing this topic. Read 2766 times.
James Romeyn
Industry Participant
James Romeyn Music and Audio, LLC
26 Mar 2004, 03:56 am »
Opinions of the CI DAC & passive preamp driving an amp with a 5k input impedance & 1.4V sensitivity (Crown)? The input impedance seems way to low to me. Thanks.
CIAudio
Facilitator
26 Mar 2004, 04:28 am »
Shouldn't be a problem...the low input impedance will insure that you have no hi freqeuncy roll off and the VDA-1 has no problem driving low impedance loads. You will have to turn the volume up higher than normal but this isn't always a bad thing as most potentiometers have their best channel to channel tracking past the 10 0'clock position. If you like, you can plug your values into the attenuation curve calculator at
http://www.dact.com/html/ac_calculator.html
Owner's Circles
CIAudio
